Sponsored by: Real Truck
rusted bed rails.
Old Apr 26, 2016 | 10:49 AM
phillycincykid's Avatar
phillycincykid
rusted bed rails.
Good Day,
I believe im using the proper terminology here, the rails, bars, brackets, whatever you may call them that run perpendicular to the truck frame that hold the truck bed to the truck, seem to have a major rust issue. i noticed the pile of rust in the driveway this morning. The worst 2 are the ones right at the wheel wells, for obvious reasons, they take on the majority of the water/salt spray. the truck bed isn't moving, however the bed has a soft spot in the area of where the picture was taken at.
My question is, what kind of a project is this to replace these bad boys, id imagine removing the entire bed at least. What is the proper name of those bars so when im calling around looking for them , i know what im talking about.
thanks for the help
Old Apr 26, 2016 | 11:28 AM
cyncwby's Avatar
cyncwby
Under truck bed support rails? I don't know but I doubt you can just go buy them from ford. They are an integral welded on part of the truck bed, could be wrong. If the bed itself is worth saving then I would use a pneumatic cut off saw and replace all the bad rails with 3/16 angle iron or whatever shape it takes. You would just have to get the bed off and figure it out.
Old Apr 26, 2016 | 11:36 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Dorman sells replacements, seems like $375 is the going rate:
Dorman Products - 924-257
Dorman 924-257 - Free Shipping on Orders Over $99 at Summit Racing
https://www.ford-trucks.com/forums/1...-supports.html
I think this was a home brew solution, look at post #16 (pic heavy):
https://www.ford-trucks.com/forums/1...r-salvage.html
Old Apr 26, 2016 | 11:37 AM
phillycincykid
i was thinking of using 1 5/8 uni strut , weld it then coating it if there was nothing really OEM , or if its a integral part of the bed. Grind all the old stuff off and start over. The bed itself is in very good shape for being 16 years old. i feel it would be worth saving.
Old Apr 26, 2016 | 11:43 AM
phillycincykid
Thanks for the info!!
If the bed comes off, i envision a project like this happening.
Old Apr 26, 2016 | 12:26 PM
ultrasks700's Avatar
ultrasks700
I brought it to a local body shop to fix. the bed was removed, underside sandblasted, cab-back frame sandblasted/painted, he made new rails from a sheet metal press, welded them in, painted and back together was 1,000$.
Old Apr 27, 2016 | 12:47 PM
madscientist's Avatar
madscientist
I did this last summer (texas tech diesel linked to my post)
It was not a hard job at all. You will have to buy or make the rails and new bed bolts and nuts (the Dorman kit had all of this included).
My post has all the details but let me know if you have other questions.
Dillon Yoder
Oct 15, 2014 12:42 AM
Neaonbhb
Jul 26, 2012 12:48 AM
ericford1984
Oct 23, 2011 07:37 PM
michael.biasi
Apr 23, 2011 12:38 AM
Roger T. Pipe
Apr 18, 2010 10:33 PM
