Sway Bar?
Old Apr 26, 2016 | 06:46 AM
Bite N Hold's Avatar
Bite N Hold
Sway Bar?
Would a sway bar help with towing my travel trailer? Probably a dumb question I'm sure. Not sure why I don't have one from the factory. Which one should I buy?
Old Apr 26, 2016 | 08:07 AM
UGA33's Avatar
UGA33
Yes. One of the better mods I have done to my truck. Hellwig is a good one.
Old Apr 26, 2016 | 08:48 AM
Bite N Hold
Easy install or shop job?
Old Apr 26, 2016 | 08:54 AM
swarf_rat's Avatar
swarf_rat
You talkin' front or rear? Most of them seem to have a front one.
I haul a camper, and an upgraded sway bar is probably the most important addition for that. I installed Hellwig Bigwig bars, much bigger than the stock front or rear. It makes the empty ride maybe a tiny bit worse and pretty much eliminates body roll.
The front one is about a 15 minute driveway job. The rear would be about 25 minutes, but the Hellwig requires you to replace the links on the rear as well, and the drivers side one is a b***h. Took me the better part of two hours to unbolt the DEF tank, slide it to the side revealing a 2" slot to work through, some swearing, etc.
Here is a comparison of stock to Hellwig, front and rear bars. Keep in mind that torsional stiffness varies as the 5th power of diameter.
Old Apr 26, 2016 | 08:58 AM
Bite N Hold
Rear is what I need as there isn't one there now and towing isn't fun.
Old Apr 26, 2016 | 10:41 AM
UGA33's Avatar
UGA33
Easy install. Extra set of hands helps.
Old Apr 26, 2016 | 10:50 AM
donovan's Avatar
donovan
What helped
I did install the Hellwig and does help holding the rear end down while on curvy roads. I have notice no difference while towing my TT. It would help with campers and 5ers. It stops the bed tilting one way or the other on sharp turns.
Old Apr 26, 2016 | 11:09 AM
smoky_diesel's Avatar
smoky_diesel
Not sure a rear sway bar would be a big help for a bumper pull TT. A top heavy load like a truck camper, absolutely.
What are the handling issue you are having? Probably sway and not body roll. What is tongue weight and do you have weight distributing hitch?
C_Smitty
Feb 28, 2026 11:02 AM
Shogunles
6.7L Power Stroke Diesel
15
Feb 26, 2015 08:22 PM
Doug913
Aug 18, 2013 02:53 PM
Boba Fett
Aug 28, 2010 07:06 PM
lslavick
Dec 26, 2005 10:52 AM
