Added Hellwig's rear sway bar...
Old Aug 17, 2013 | 07:02 PM
Doug913's Avatar
Doug913
Recently I purchased and added "Hellwigs' rear sway bar to my '11 f350sb 4x4. While driving I can tell that the truck corners much flatter in the turns then it used to. I haven't tried it yet with the 5th wheel on the truck, but I figure that with all that weight back there I probably won't notice anything.
Here is the 7714 kit. There isn't much to it but that sway bar has some weight behind it.
Once installed.
The hardest part is behind the def tank. I have a swb truck so it was a long reach up to where it mounts. It can be done but it makes the job last a while longer. I suspect it was a few hours to install and most of that was the upper left side.
I initially installed the link bars in the hole that the instructions suggested (in picture) but after a few drives, I moved it to the middle hole and that is where I noticed it was helping so I left it. I have not tried the 3rd hole as of yet and I probably won't.
So far no squeaks or any adverse effects that I can tell. As you can see I also have the bilstein shocks, but I find them pretty stiff with nothing in the bed of the truck. Once I have a m/c back there the ride is much nicer then the stock fx4 shocks.
Old Aug 17, 2013 | 07:24 PM
2ndStroke's Avatar
2ndStroke
Good job, looks like a quality kit
Beefier then my stock bar
Old Aug 17, 2013 | 07:34 PM
TRENT310's Avatar
TRENT310
I like how it's on the top side of the diff so that there's no chance of it scraping on anything. My OEM sway bar hangs a bit low especially now with the lift springs. I already put longer end links but it's a tradeoff between the front part of the swaybar hanging too low or the rear part since it pivots on the bottom side of the axle.... this design eliminates that problem entirely.
Old Aug 18, 2013 | 10:39 AM
ggadwa's Avatar
ggadwa
Hellwig SWAY BAR
I actually installed the FoMoCo sway bar on my 2012 F350 after ordering the specific parts from FORD....I had a 2000 F-250 with the stock Heavy duty Sway Bar. Ford's current sway bar is tiny in comparison to Hellwig. I sure wish I had known about the Hellwig Bar before I bought the FORD unit!!!! FORD shop tried to tell me the new flimsy bar is comouter designed to work as well as the Heavy duty bar.....I think its more like.... just one more effort to reduce truck weight.
GARY
Old Aug 18, 2013 | 02:47 PM
Dim Sum's Avatar
Dim Sum
Thanks to you , I now have to put the Helwig sway bar on my list of things to buy for the truck.
Thanks....
Old Aug 18, 2013 | 02:53 PM
TRENT310's Avatar
TRENT310
How much adjustment do the linkages offer? Do they make a longer length version?
robstait
Mar 26, 2020 11:29 PM
Shogunles
6.7L Power Stroke Diesel
15
Feb 26, 2015 08:22 PM
ggadwa
Oct 31, 2013 05:45 AM
SpokaneJim
Apr 28, 2010 09:31 AM
shivelyt
Apr 3, 2004 09:42 AM
