cracked injector tip
Old Apr 25, 2016 | 04:36 PM
ss72450's Avatar
ss72450
Thanks for all the valuable info here. My question is can a cracked injector tip let gases back in the fuel system?
Old Apr 25, 2016 | 05:38 PM
wedge542's Avatar
wedge542
Yes it can, pull the filter out, use the crank wire on left fender to turn motor look at bubbles in filter housing while cranking.
Old Apr 25, 2016 | 07:06 PM
ss72450's Avatar
ss72450
Thanks, I tried that first and it actually blew fuel out of the bowl. I then did the balloons to see what side it was and pulled those injectors. I found one with a cracked tip and everything else looked ok. I was having a problem with heavy smoke and pretty sure the cracked tip was the cause of that, just wasnt sure about all the air.
Old Apr 25, 2016 | 07:58 PM
m-chan68's Avatar
m-chan68
The bigger, and most important question will be WHERE the end of the broken tip ended up, and how much damage did it cause?
Old Apr 25, 2016 | 08:24 PM
87crewdually's Avatar
87crewdually
........ and to add to m-chan68's post, how long were you driving it like that. Fuel dumping from a cracked tip is a good way to torch and melt piston tops.
I'd check compression with a gauge to be on the safe side. Compare all cylinders and they should be within 10% of each other.
Also next time when you do the balloon/bubble test, pull one glow plug at a time until the bubbles stop. Then you know that's the problem cylinder.
Hopefully all is well. If it burnt a hole it would build pressure in the crankcase.
EARLYTIMES
Oct 3, 2013 01:37 PM
2006powerstroke90
Sep 20, 2011 10:33 PM
Wings
Oct 10, 2005 11:44 AM
OGEEEZ
Apr 7, 2005 09:54 PM
