95 460 EFI rebuild options
Old Apr 25, 2016 | 03:17 PM
mxer0022's Avatar
mxer0022
Ok guys so I've decided to do a rebuild on my 95 EFI 460 and was wondering about my options for piston type and cam. If I go with flat top pistons and an rv cam what am I going to have to do to my EFI if anything to make them work? Will I even be able to go with flat top pistons? What are some good kits to look at that won't break the bank and which cam can I use? Just figure if I'm gonna be doing it I may as well get a little bit of a performance upgrade. I've already got headers and will be putting on a 3" exhaust.
Let me hear you recommendations and experiences! All are welcomed.
Old Apr 26, 2016 | 07:35 PM
cbakker's Avatar
cbakker
You can't get too crazy with the cam unless you do a MAF swap. I'm not sure what options there are for flat tops, but most guys use the smaller dished pistons from the 88-92 blocks.
Old Apr 27, 2016 | 01:35 AM
mxer0022's Avatar
mxer0022
I was told on the 429-460 forums to use speedpro H535P flat top pistons and mill the block .025" for better quench then buy a custom ground cam specifically for speed density EFI. Also to port the intake.
Does this sound like it'll work well?
Old Apr 27, 2016 | 05:28 AM
cbakker's Avatar
cbakker
It could work. That is a lot to take off the block, and your compression may be too high to run regular unleaded gas at that point. The main thing for a speed density friendly cam is that it needs to maintain a high enough vac level at idle. The PCM will compensate for the resulting changes from a mild cam upgrade, but that's it. I would look at the EFI friendly cams from lunati and comp.
Old Apr 27, 2016 | 06:05 AM
mxer0022's Avatar
mxer0022
He said that just the pistons would put it to 9:1then milling the block would push it to 9.4:1
Old Apr 28, 2016 | 01:57 PM
mxer0022's Avatar
mxer0022
So here are the specs that comp recommends. This isn't too much for my speed density set up is it?
Inline image 2Inline image 3
Description
Part Number:
34-239-4
Grind Number:
X4270H
Lifter Type:
Hydraulic Lifter
Specifications Intake Exhaust
RPM Range:
1600 to 5800
Valve Lash:
Hyd.
Hyd.
Valve Timing:
0.006
Duration:
270
278
Lobe Separation:
111°
Duration @ .050" Lift:
226
234
Intake Centerline:
107°
Valve Lift:
0.554
0.574
Lobe Lift:
0.32
0.332
Valve Timing @ 0.006 Lift:
Exhaust
Closes 24
ATDC
Opens 74
BBDC
107Valve Timing Diagram
Intake
28 Opens
BTDC
62 Closes
ABDC
Old Apr 29, 2016 | 11:11 PM
cbakker's Avatar
cbakker
When I was doing research on my rebuild I called the ford racing guys at FRPP. I believe he told me anything more than about 215 duration at .050 was too much for the SD system to allot for. I am sure it had something to do with the SD PCM not being able to match the right amount of fuel to the lower idle vacuum created by that big of a cam. I don't even think my cam is that big and I did a MAF swap to make sure it could handle it. My cam is the 34-235-4. I will do a little more research on that cam though.
Old Apr 30, 2016 | 02:11 AM
mxer0022's Avatar
mxer0022
I heard from Randy Malik on the 429-460 forum and he said that cam was so wrong that the comp cam tech who suggested it should be fired. He said that my heads can't even take that amount of lift without modifications. So I am just gonna have him grind me a custom cam. He seems to have done a lot of good work on these SD EFI systems.
Old May 1, 2016 | 01:08 AM
cbakker's Avatar
cbakker
Yeah I thought it seemed like a strange rec also. I trusted my builder to handle the valvetrain issues that might arise from the bigger cam, and he made sure that it was fully functional with my set up before he let me take it home. Hopefully u can get a reasonable price on a custom cam going that route. There are alternatives through the various cam manufacturers that should work for an SD setup.
Old May 1, 2016 | 10:24 AM
Heavy97Duty's Avatar
Heavy97Duty
check these guys out
Re in"Car"nation High Performance - Home
Old May 5, 2016 | 08:25 AM
lesoster's Avatar
lesoster
You should review my post "460 EFI Ultimate Build" posted on 9-27-08.
I did a complete rebuild on my 97 F250, 460 EFI w/MAP. This post provides a list of all components used in the build. The end result is a truck that is completely reliable, with greater low end torque and smog legal. The high end power is better than stock, however it is by no means a race truck.
Best Wishes
LO
Old Apr 16, 2019 | 08:24 PM
covetablender's Avatar
covetablender
4th Gear
Quality Shops in CT/NY?
Can anyone recommend a shop in CT or near NYC that knows what they're doing for a performance rebuild on a 460 EFI?
Old Apr 17, 2019 | 03:00 PM
cbakker's Avatar
cbakker
Covetable, what kind of build are you doing? If you stay with the factory equivalent or EFI friendly cam, you don't need a specific builder. I would just try to find someone whom has built big blocks before.
Old Apr 28, 2019 | 09:30 PM
covetablender
4th Gear
Thanks cbakker. How far I take the build is going to depend on the shop I find to do the work. If I can't find someone reasonably close by who has been down this road before, I will stick with an EFI friendly cam.
mxer0022
Apr 30, 2016 11:18 PM
sisabdulax
Mar 17, 2015 03:06 PM
OldRacerGuy
Sep 30, 2008 03:07 PM
Mr Man
May 18, 2004 06:04 AM
