PMS overload
Old Apr 25, 2016 | 01:35 PM
wameyer's Avatar
wameyer
PMS overload
Well, where do I start. I have a '99 F250 7.3 265k, I bought a 28' bumper pull toy hauler around Easter to tote my race bikes and have a place to sleep instead of tent. After buying it I knew my truck needed to better off pulling it so I started with small things fixed the fuel bowl for the umpteen time at the valve, noticed I had an oil leak so I bought a new ICP (leaking through top). Then the fun began.... still had an oil leak so I bought riff raffs billet plenums. I wasnt thinking but I noticed I had to take my turbo off, after all the parts arrived I read the instructions it said remove turbo, low and behold my center housing was the oil leak and noticed my EBV had blown the seal out on the flange of the turbo, my pedestal is fine.
All in all parts bought
FRX
HPX
High flow CVD fittings and Banjo fitting Riff Raff
Bellowed up pipes
EBV deleted flange (high flow outlet)
4" turbo back diamond exhaust
Hutch and Harpoon
DP Tuner
Riff Raff plenums
7+7 compressor wheel
Went alittle overboard but after being down a week and making 3 weekends of working on my truck I was tired of laying on the ground and being under the hood, to top it off my old ('59 apache caught fire while driving while my 7.3 was down) Now have to fix other truck.
Must say Im happy with everything need to add a switch pod some where thought of the 650 dash and thinking of the AIS system. Think Ive about covered most Mods.
Old Apr 25, 2016 | 01:57 PM
HKusp's Avatar
HKusp
Nice, what intake are you running right now?
Old Apr 25, 2016 | 02:02 PM
Walleye Hunter's Avatar
Walleye Hunter
That sounds like a heap of work, you got it all done?
Old Apr 25, 2016 | 02:21 PM
wameyer's Avatar
wameyer
Got it all done, yes it was a big heap took me 14 hours but now its driving and I love it.
Running stock intake/ spider
Old Apr 25, 2016 | 03:10 PM
HKusp's Avatar
HKusp
You need to at least get a 6637 filter and go from there. Stock you are certainly not flowing enough air for the improved fueling you are seeing with the tuning you have.
Old Apr 25, 2016 | 05:02 PM
white Buffalo's Avatar
white Buffalo
Probably resulted in a nice drop in towing EGT's with those upgrades.......
But like Hkusp suggested a 6637, S&B or a Ford AIS intake would give her the extra air she's calling for.......
Old Apr 25, 2016 | 07:57 PM
wameyer's Avatar
wameyer
Ive got a K&N Cone filter.
Old Apr 25, 2016 | 08:25 PM
Jaime74656's Avatar
Jaime74656
I would change to the AIS at the minimum and dump the K&N filter, I would even be hesitant to use it if it was one specifically designed for diesels...
B-Rad88
Mar 5, 2018 09:52 AM
Doc Feel Good
May 24, 2011 11:19 PM
Speedster93b
Jun 11, 2009 11:30 AM
rbi
Sep 16, 2007 10:34 AM
CAT_man_963
46
Feb 2, 2006 06:12 PM
