Can't Pull codes 86 F-OneFive?
Old Apr 25, 2016 | 11:44 AM
Joeblowv1's Avatar
Joeblowv1
Hey everyone,
After a hiatus from finding new things to work on due to a simple gear oil top-off turning into pulling my transmission (I dropped some tubing into my fill plug) then pulling again (release bearing was sitting in my bellhousing)........and again (shifter arms weren't working right)....I've finally got it working. The Srod OD/RTS OD is a fiddly transmission to say the least.
Anywho, a quick ride around the block and a sprint on the highway has got the old gal moving again. But my carb is in desperate need of rebuild, my car smells more gassy than ever! While my trans was out I got a code reader so I can see if theres anything else that needs replacing while I have the carb off. .
Well now when I try to pull codes I get nada. My plug was pretty corroded so I stuck some sandpaper in there, and used some dielectric grease, but I get absolutely nothing. I had a friend pushing the clutch for the KOEO codes, and wasn't getting anything KOER tests either.
Besides jumping the ground, what should I be testing? Any protips about getting the EEC-IV to throw you its codes?
Old Apr 25, 2016 | 02:39 PM
1986F150six's Avatar
1986F150six
Our Moderator, ctubutis, provided this link, some time ago. If your system is still intact, perhaps this will help!
Ford Ranger - Testing EEC-IV Equipped Engines
Old Jun 22, 2016 | 11:39 AM
Truckandute's Avatar
Truckandute
I'm back. Finally found time to get into the workshop.
I followed throughout test procedure and ended up at step b9 12v battery power fault isolation.
Result being a 13v.
So I either have a short to ground or an open vpwr circuit from eec power relay to processor connector.
I tested pins 37 and 57
Pin 37 was 13v
Pin 57 was 0.9 volts
I also tested pins 40 and 60 (power ground)
These both read 13v
So my belief is ive got a short to ground somewhere... Is this correct?
Old Jun 22, 2016 | 11:44 AM
Truckandute
Result being a 13v.
Pin 37 was 13v
These both read 13v
Sorry replied to wrong thread.
Motohead911
May 24, 2019 10:24 PM
have3fords
Bronco II
Oct 25, 2007 02:30 PM
Corso
1983 - 2012 Ranger & B-Series
Dec 15, 2005 06:57 AM
mudbone1979
Bronco II
Sep 8, 2004 08:24 PM
91ford_ranger
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Jul 30, 2004 01:39 PM
