Sponsored by: Auxito
Keyless door code?
Old Apr 25, 2016 | 09:22 AM
Coach66's Avatar
Coach66
Keyless door code?
I have searched and found info on door codes for '09's, '10's, and an '02. But have yet to locate the lock module that has the sticker with the code on it for my recently purchased '03. I have check all the paper work and manuals. I thought it would probably be like the '02 I read about, but couldn't see anything that look like what they were describing.
While we are at it my I just bought my wife a '15 Fusion with the same problem. Nothing in the paper work. So, if anyone knows where that cade is hidden, it would be a big help also.
Thanks in advance for any and all help.
Old Apr 25, 2016 | 08:15 PM
steve(ill)'s Avatar
steve(ill)
the 01-02-03 are normally on the white receiver box... lay on the drivers floor and look up above the steering wheel shaft toward the firewall.. Is there a white box maybe 4 inches square ? That is the receiver and normally has the code sticker on the side. ........ you have a factory door keypad or FOBS ?
Old Apr 25, 2016 | 08:27 PM
kd4gij's Avatar
kd4gij
Is yours wired or wireless?
Old Apr 26, 2016 | 09:39 AM
Coach66's Avatar
Coach66
I have the door key pad and factory fobs.
I am not sure of wired or wireless. I'm assuming wired as it is factory.
Old Apr 26, 2016 | 04:31 PM
steve(ill)'s Avatar
steve(ill)
since your truck came with FOBS then you can assume you have the receiver box. Look under the dash above the steering.......... My 2002 came without the door pad. I bought a wireless unit on line and you install with double stick tape. It is programmed just like the FOB which is wireless......... my code was on the side of the white receiver box.
Old Apr 26, 2016 | 04:33 PM
kd4gij's Avatar
kd4gij
does it look like this one.
NEW 7L2Z-14A626-BA F150 Genuine Ford Explorer Parts Keyless Entry Keypad
Old Apr 28, 2016 | 03:10 PM
Coach66's Avatar
Coach66
Mine doesn't.
GeneLaw1
Jul 28, 2015 10:39 PM
cnelso48
Sep 3, 2009 03:25 PM
mercman86
General Automotive Discussion
Apr 6, 2008 03:38 PM
RAGaz
Apr 25, 2007 10:00 AM
dominic1029
Jul 12, 2006 08:15 PM
