rear end issue
Old Apr 24, 2016 | 07:34 PM
87crewdually's Avatar
87crewdually
Originally Posted by 2005powerstroke4WD
So the fact it is a dually means it is a Dana 80?
I'm almost certain in all 1999 F350 dullies came with a Dana 80 rear. 1999+ SRW came with Sterling 10.5. 93-97 had Sterling 10.25 long pinion. IIRC 1993 down had a short pinion Sterling10.25.
I know for certain the rear covers are different on a SRW & DRW 2005 F350.
Old Apr 24, 2016 | 07:48 PM
Jerky's_06 F350's Avatar
Jerky's_06 F350
My 06 F350 SRW is the Sterling 10.5.
Old Apr 24, 2016 | 10:13 PM
Thor'sHammer's Avatar
Thor'sHammer
Dana rears are only in dually Super Duties. SRW SDs have the 10.5 rear axle.
Old Apr 25, 2016 | 10:33 AM
2005powerstroke4WD's Avatar
2005powerstroke4WD
Apparently this is not the company that makes the USA Standard gear set. They make US Gear.
Old Apr 25, 2016 | 12:49 PM
2005powerstroke4WD
So any other option or will I just have to buy another set from a manufacturer that actually supports their product?
Old Apr 25, 2016 | 06:47 PM
rhjj's Avatar
rhjj
Can you get any info from the place you bought them? If they cant help you return the items and buy from a better supplier.
Old Apr 25, 2016 | 08:09 PM
2005powerstroke4WD
They came with the truck. I knew ahead of time they need to be changed. No idea where they were bought.
Old Apr 25, 2016 | 08:15 PM
rhjj's Avatar
rhjj
I would go to there website and call one of the distributors and see if they can help. If you get no place, bite the bullet and buy from a place that will stand behind the product.
Old Apr 26, 2016 | 07:09 PM
2005powerstroke4WD
Well, I did "bite the bullet". Got these:
https://www.ringpinion.com/b2c/Produ...rd&ShowAA=true
The sales dude was aware of the ring gear problem. Came with a lifetime warranty too. Thanks for the help guys.
Old Apr 26, 2016 | 07:22 PM
rhjj's Avatar
rhjj
Sorry you had to buy a set but at least you have a company to call if you have a problem.
Old Apr 26, 2016 | 07:58 PM
87crewdually
I think the problem you were having was the guy that gave you the set bought the wrong ones for a different carrier. 2 sets are available depending on what carrier your truck has depending on the stock gear ratio. The set you linked is for a carrier 4.10 and higher.
I ran into this doing an axle build & gear swap on a Jeep with Trutrac lockers.
Glad you got it worked out.
dmullin4
Jun 15, 2018 05:11 PM
60'BigBlue
Jan 17, 2016 11:20 AM
Bender99
Offroad & 4x4
18
Jul 29, 2009 03:59 PM
dylan1952
Dec 25, 2006 10:04 PM
Butch(OH)
Jul 12, 2006 07:03 AM
