Blend door
Old Apr 26, 2016 | 05:46 AM
JWA's Avatar
JWA
Originally Posted by ligito
I see mention of the easy way, what is it?
Remove the passenger side plastic lower dash trim panel then the metal support structure that doubles as part of the anti-submarine crash "protection" feature. Remove drive motor.
Next remove the 7-9 7mm hex head screws from the outer heater coil cover, somewhat forcibly yank it straight out, bending it slightly so it comes free. This is best done when the van interior is at least 50*F---the case is flexible enough for removal when its warm, not much lower than 50*F
Its important to pull straight out because the case has a drain leading through the other half of the case to the inside of the engine bay. Here's some photos, no particular order:
Old May 14, 2016 | 01:20 PM
ligito's Avatar
ligito
Thank you.
jrh32
Dec 19, 2016 11:14 PM
Jo R Cl
1997 - 2003 F150
Oct 15, 2003 10:47 PM
taxidriver
Oct 4, 2003 01:00 PM
Kimmig12
1997 - 2003 F150
Mar 29, 2003 12:36 AM
cwill
Apr 27, 2002 05:40 PM
