'00 E250 rear door stops
What are the rear cargo door stops called? I need a couple sets of the part that mounts to the body with the stainless steel retainer clip and the arm that retracts into the door.
Is there an aftermarket product or would this be a Ford product? I did not find it on RockAuto. Anyone have a lead where to buy if avail aftermarket?
Thanks
Thanks
https://www.ford-trucks.com/forums/1...sing-help.html
They're available separately, I'd buy those parts only from the dealer but budget is never my primary concern.
The biggest issue trying to find and retrieve them at the scrap yard is the very soft Torx-headed screws--prone to having been corroded inside the threaded body holes, the Torx recess becoming stripped out fasert than you might imagine---without a suitable impact tool anyway.
Body side: Door Check Bracket F2UZ-1527218 A ; Door side: Check Arm F3UZ 1527204 A. These numbers apply to model years 1992 > 2005 if you're scrap yard shopping.
