1983 Ford Ranger Multifunction switch rewire
Old Apr 21, 2016 | 01:23 AM
SladesRanger's Avatar
SladesRanger
Hey guys first time posting. I have been working on rewiring a 1983 ford ranger that I have been pretty much rebuilding over the last few weeks. I ran into kind of a snag with the multifucntion switch (both the turn signals and the headlight dimmer switch). I have looked all over forums, google, library and I can not find a pinout diagram or even a guide that someone has put together to say which wire goes to where.
If anyone knows of where I can find or provide me with a simple
-Green wire on Circuit (number here) goes to the Right rear turn single....
Or something like that I would be so grateful. Thanks if you took the time to read this. I think that broncos in similar years probably had the same setup so that might work as well if anyone knows anything.
Old Apr 21, 2016 | 08:45 AM
tomw's Avatar
tomw
Check the web for the EVTM - electrical vacuum troubleshooting manual - which provides the layout and wiring of just about everything you want to know.
r/y dimmer
lg/bk dimmer high
r/bk dimmer low
lb hazard (power in?)
w/rh hazard
lg brake turn (power in?)
o/lb right turn
w/lb riight turn
lg/o left turn
lg/w left turn
from the book pg 126 for a 1985
tom
ccopes75
Electrical Systems/Wiring
May 3, 2010 09:43 PM
alex76-f250
Jan 11, 2010 11:39 PM
bgblktruk
1978 - 1996 Big Bronco
Jul 4, 2006 12:54 PM
TigerDan
Dec 24, 2004 12:52 AM
Hilljack21
Jul 12, 2003 12:34 AM
