AC Conversion -> Evaporator Core
Old Apr 20, 2016 | 09:42 AM
SomeDude451's Avatar
SomeDude451
Looks like in my area it'll be cheaper to convert to r134 than stay with r12. If I'm going to go that route, I'm going to replace the entire system so it functions properly.
That being said, does anyone know if the later style evaporator core, say '94-'96 (OBS), fit in the airbox of an earlier model, like my '89? If it doesn't, will the whole airbox fit on the truck?
Old Apr 20, 2016 | 10:05 AM
sgip2000's Avatar
sgip2000
Unless your evap is leaking, I'd just leave it as is. No real benefit to "upgrading" it. The condenser is what you want to look at. That is the part that actually removes the heat.
Old Apr 20, 2016 | 10:40 AM
SomeDude451
There is a point. r134 will seep out of the hoses designed for r12 over time. So those need to be replaced. Which means all the components touching them do because they're in different locations. It gets hot and humid here and I don't want to have to deal with regularly recharging a cobbled together solution.
Old Apr 20, 2016 | 10:46 AM
rla2005's Avatar
rla2005
To the best of my knowledge the evap is the same size for R12 vs. R134a systems. As noted, the fittings are different. Should be a plug-n-play swap.
IIRC correctly Steve83 swapped in a complete R134a system that was already connected and charged. I think that was in his '83 Bronco.....
Old Apr 20, 2016 | 10:57 AM
sgip2000's Avatar
sgip2000
Just replace the hoses, flush the metal parts, add proper oil, pull a vacuum, fill.
Old Apr 20, 2016 | 12:34 PM
GuitarJesus's Avatar
GuitarJesus
There is something to be said for the conversion fittings being spots that will leak. But so are the stupid little Schrader valves on the high and low pressure fittings. If you really feel the need to get a 92-96 evaporator, just get one from the JY and flush it out really well. But as sgip2000 memtioned, you do need the 92-96 condenser. Big time difference. Also, if you are doing this yourself, remember Ford had a TSB that they upped the r134a amount to 38oz.
http://www.thedieselstop.com/faq/949...les/941920.pdf
Old Apr 20, 2016 | 12:46 PM
jas88's Avatar
jas88
I converted my '91 F150 to R134a about 6-7 years ago and I replaced everything *except* the evap core. The fittings are different, so I had a custom liquid line made to fit the newer condenser and the older evap core. It didn't cost very much, I believe it was under $50. Oh yeah I put in a red orifice tube, replacing the blue one.
Old Apr 20, 2016 | 07:11 PM
kellen302's Avatar
kellen302
That's correct on the red orifice tube, if you do switch to a later evap core (I did when I swapped my entire system) then the evaporator core box needs to have a notch cut where the top hose comes out because the later evaporator core has slightly different hose routing. A hack saw or dremel and some black rtv finishes it easily.
silverorange
May 2, 2017 06:58 PM
Josed87
Jun 30, 2011 10:15 PM
rutang
May 20, 2006 12:26 PM
bronzeback
Sep 9, 2005 10:01 AM
tmcalavy
Sep 20, 1999 10:14 AM
