1990 e4od issues
Old Apr 19, 2016 | 09:55 PM
wahlturfcare's Avatar
wahlturfcare
1990 e4od issues
I have a 1990 superduty truck with a 7.3 that I've been fighting the solenoid pack issue for some time.
But today while driving after leaving a stop light. My truck started making a load squeaking sound under the can with alittle shudder. So I took it easy down the block towards a parts store. I noticed that it was loosing power in 2nd completely too and that reverse is gone. I was able to drive it home though (15 miles) doing highway speed.
What could it be? Torque converter, sticky valves, parking brake on back of tranny?
Ever since I had the truck, it wouldn't downshift on its own and scaning it, it gives the codes for the solenoid being bad.
Old Apr 19, 2016 | 10:16 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
uh oh.sounds like the converter is coming undone.the can of marbles sound along with shudder.the bad news is,the shavings from the converter ruins the trans and requires a reman.with no reverse and low gears going,im afraid she's done.
if your going to look for a used trans,remember it's a 4wd version (driveline brake instead of t-case.)
try and source a 95-97 version.they have a lot of upgrades over the '89-94 versions.you'll just need a new 4 stud diesel converter and a new 89-94 solenoid pack to put in it.
if you can find an early trans with a ford reman sticker,these have been updated to '95 spec too.
you'll need your radiators trans cooler flushed and you'll need to throw away your aux cooler and replace it.
big ole ford
Nov 27, 2014 12:44 PM
monstergarage87
Jan 29, 2012 05:16 PM
cornbinder
Apr 17, 2008 06:03 AM
ace866286
Jan 24, 2005 07:48 AM
tom 400 cfi
Jan 18, 2001 05:51 PM
