1949 F1 Build Any Pointers ??
Old Apr 21, 2016 | 12:35 AM
mikeycoletta's Avatar
mikeycoletta
Originally Posted by old_dan
Hello and welcome to the forum.
Your bed parts look pretty good. If there is a lot of damage and rust that isn't showing in your pictures, I think Northern Classic Truck is the place to get bed parts. He is one of the manufacturers with the proper tooling. Many other suppliers are re-sellers & this guy is the real deal.
Before I bought the bed, I happened to be in Michigan on a business trip, so I stopped in to see their shop & take a look at the products. It was interesting to see raw sheet metal being stamped into Ford parts.
Dan
Thank you i checked out the website i think I'm def just gonna order a whole bed kit seems to be the way to go thanks again ..
Old Apr 21, 2016 | 12:58 AM
ben73058's Avatar
ben73058
Hey Mike,
AOD's can be pretty touchy - that cable has to be set just right.
That transmisson will dissolve if that pressure isn't just right. Find someone that really knows
them to help you get it set up. You will have the best luck using a Lokar shifter - kind of pricey
but you will save a lot of aggravation.
You can beef up the AOD with AODE internals if you are running a
bit of an aggressive 351W. We are running the larger 2 inch Kevlar Overdrive band &
the larger Reverse Drum. We drive around town in D & only use O (Overdrive when going
over 50 on the highway. If you try to ram it into overdrive with a hard shift .....
AOD's come in 3 basic flavors A, B, & C. C has the small 1.5 inch servo - that's not the one you want.
Look for an A type AOD - common in V8 Lincoln Mark VIII engines - our's is from a V8 Tbird.
Good luck over there.
Ben in Austin
1950 F1
Old Apr 23, 2016 | 04:07 PM
petemcl's Avatar
petemcl
I agree with Dan. Northern Classic Truck maintains their dies so parts fit as designed. You should find your '49 bed sides on this page with pictures:
http://www.northernclassictrucks.com/Bed_Parts.htm
52 and 76
Apr 15, 2018 06:08 AM
Tombstone Todd
17
Nov 19, 2012 07:50 AM
hillbilly1951
69
Oct 9, 2012 08:02 PM
Bob_1
Aug 26, 2010 07:55 AM
Retired_Colonel
Dec 21, 2009 09:00 PM
