useing two piece drive shaft
Old Apr 19, 2016 | 11:27 AM
1949f1's Avatar
1949f1
has anybody run a two piece drive shaft in a 49f1. my 390 and c6 are ready to come out and forgot it had a two piece shaft until I crawled under it this morning.
Old Apr 19, 2016 | 01:10 PM
Scotty's 52 F3's Avatar
Scotty's 52 F3
I wouldn't run a two piece unless I had to.
Old Apr 19, 2016 | 01:44 PM
1949f1's Avatar
1949f1
my c6 has a fixed yoke and it is from a 1969 f250 truck. I could try it or find a bell housing and flex plate that would fit a fmx that I have. if I make a cross member for the carrier bearing it may work but I will need the rear shaft cut to fit. one thing after another but if it was all was easy anybody could do it
Old Apr 19, 2016 | 03:17 PM
CBeav's Avatar
CBeav
Or have a driveshaft with a slip yoke made to fit...
Old Apr 19, 2016 | 09:08 PM
Jules The Great's Avatar
Jules The Great
You may be able to source another C6 with a slip yoke I think they made them later in the 70's if you can get the drive shaft too then just have that shortened?
Old Apr 20, 2016 | 03:26 AM
1949f1's Avatar
1949f1
being on disability and money is tight so I will run it since I know it's a good tranny. I don't know why I didn't think of running a shaft with a slip joint. Thanks' for the reminder of using one
jejdavis
May 18, 2013 05:44 PM
trevor8283
Aug 29, 2012 07:09 PM
rb76543
Jun 11, 2010 11:17 PM
1972ford_f-100
Jul 16, 2004 12:48 PM
