drive shaft problem
Old Aug 29, 2012 | 06:15 PM
trevor8283's Avatar
trevor8283
drive shaft problem
i have a 48 f1 289 c6 when i replaced the dana 41 rearend for a 9in. i started spinning the rear bushing and seal out of the tail shaft of the trans. i think my driveshaft is now to short. does anybody know of a replace shaft that might work. my thinking is a 80-84 ranger extended cab 4x4 2 piece hoping the cross member for the center hanger bearing will work.
Old Aug 29, 2012 | 07:05 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I measured and found with the 9" the driveshaft was 1" too short. I solved that by switching the yoke on the 9" for an extended one (exactly 1" longer) than the one that was on there. Otherwise you need to have a new driveshaft made, about $200. When you put on the new yoke, you really need to make sure the pinion bearings are preloaded correctly.
Old Aug 29, 2012 | 07:06 PM
jaye's Avatar
jaye
I would take measurements and let a shop make or cut a drive shaft to fit. You can go to a pull-a-part yard and get one (or just the yoke) from anything with the same year c6 the cut/lengthen
Old Aug 29, 2012 | 07:09 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ooops never mind
1949f1
Apr 20, 2016 03:26 AM
postalxj
Dec 19, 2009 01:10 PM
custom cabby
Apr 7, 2008 11:02 AM
1972ford_f-100
Jul 16, 2004 12:48 PM
Bronson 302
Jul 6, 2004 10:46 PM
