Door hing & paint
Old Apr 19, 2016 | 10:36 AM
schoo's Avatar
schoo
Door hing & paint
Did you weld the hinges back on or not.
If you did weld them back was that before paint? Or after paint and spot paint it to cover
49 F1
Thanks guys
Old Apr 20, 2016 | 01:11 PM
schoo's Avatar
schoo
Rechecked the door fit and welded before paint
Old Apr 20, 2016 | 03:48 PM
41505379's Avatar
41505379
On my 50 F-3 I painted the doors supported by the hinges screwed to upright 2x6s and the cab separately. I never rewelded the hinges to the cab. It only originally had very small spot welds anyway. I did use the welds to help me align the doors when they went back on. Patrick
Old Apr 20, 2016 | 04:26 PM
schoo's Avatar
schoo
How long has it been after you rehung the doors any droop?
Old Apr 21, 2016 | 06:19 AM
41505379's Avatar
41505379
I rehung the doors about 20 years ago. No droop. patrick
Old Apr 21, 2016 | 07:51 AM
raytasch's Avatar
raytasch
Believe Nothing
If I were doing it, I would have the doors firmly in place prior to paint.
Old Apr 21, 2016 | 08:04 AM
schoo's Avatar
schoo
I have had the doors on with the cab mounted on the frame two times. The thing I'm concerned about is fitting after the rubber is on if I have to Ajust the hinge and I won't know that until I try it.
Thanks
Old Apr 21, 2016 | 02:34 PM
41505379's Avatar
41505379
Further explanation of painting doors. I had an upright 2x6 fastened to the floor and to the roof trusses in my garage. I bolted or screwed the hinges with the doors attached to this 2x6. That way I could spray paint the outside, inside (towards cab) and the edges of the doors all at the same time with no overspray or masking of the doors. I don't remember if I used one or two 2x6s. Somewhere I have pictures but that was before digital, so they are in a drawer somewhere.
That is not how we did it in the body shop but it worked out well. Patrick
GoldCo
Sep 29, 2018 05:19 PM
Redeyeracing
Aug 13, 2016 11:53 AM
Clem's Cousin
Paint & Bodywork
Feb 23, 2016 10:16 PM
boxcar1974
Paint & Bodywork
Mar 21, 2007 08:04 AM
1olddog2
Aug 9, 2004 12:25 PM
