This past weekend I had my points slip and close 2x's....I have a 352 FE and decided to switch to electronic ignition...I've had some people suggest DUI(Davis Unified Ignition) and others say PerTronix Flame Thrower 2
The petronix has been around for a while, works well, I have been using them for 20 years. As things evolve better options become available. I don't know what's best, just can say the Petronix is good.
I'm a little confused. The Flamethrower and Flamethower II are coils (I believe both are internally resisted so don't need a ballast). I used one about 9 years and was happy. But you're talking about the points and if you want the Petronix version then you want their Ignitor or Ignitor II. I've been happy with them as well. You may even be able to swap an Ignitor into your existing distributor...can't remember for sure because it's been a while.
Correction for what I said (after looking at the Petronix site). They have a Flame thrower distributor too which has the ignitor inside. As my memory comes back, their distributor was fairly easy to change the advance curve if you feel the need. You'll need some dentist type picks to handle the tiny springs should you want to adjust the curve.
I had the Flame Thrower 2 in mine for a while. It ran good, But I switched to a cheap HEI by CRT Performance and it runs even better. I think my old dizzy was getting a little worn.
There's nothing simpler than dropping an Ignitor module in to replace points. They are not so affected by a worn distributor like points. In fact that may be why so many make the conversion, when the shaft runout becomes just a little too large the points are going to wobble and the dwell won't be steady and will give constant trouble. Take the time to make sure the advance curve is where you want it while you're at it.
I have the Ignitor III and Flamethrower III. Installed them on original worn dizzy and worked fine for awhile. When I popped in a reman dizzy, only $50, it has worked well.
I've had a Performance Distributors (DUI) Duraspark setup installed for about 7 years now. That's their distributor, box, coil, and wires. My truck is driven daily and year 'round in Atlanta. I've made a couple 1200 mile round trips with it. I have not had one problem.
There was a noticeable improvement, over the previous points setup, to the low end, nothing significant, but still noticeable.
Since you have an FE, you probably have a choice of Duraspark or GM HEI style. While I would expect the same results of the GM style, but it's not what I have and I have not used one so I have no idea how they compare. GM HEI will not fit in the space allowed by my Y-Block.
I have had a Pertronix Ignitor II module and flamethrower II coil that I could tell no difference at all over points - same mileage, same idle and running characteristics, no perceived change in power.
My truck did run better with the Pertronix. The other reason I like it is the stock look. If you don't care about the looks, then there's probably better performance with the Duraspark or MSD mentioned.
I ran a CRT for numerous years as well on a 73 F250 with a 360 and loved it so much I put one on my other Ford engine as well. You'll need a 10" air filter assy or smaller though, because it sits up high and large.
Sorry been away for a while(crashed computer)....thanks for all the input....haven't made my decision yet but I will post what I decide once completed...
