C6 wont shift up into 3rd
Old Apr 18, 2016 | 08:39 PM
Nicktitan's Avatar
Nicktitan
I just rebuilt the 390 in my 70 pickup and the c6 came out with it. I didn't touch the trans besides putting a new front seal on it, but now that I have the truck moving again, I don't get high gear. First to second shift is decent, even though I had to wire the kickdown down so I could drive it until I could get the holley kickdown extension. But I can give it full goose and the trans just won't give me 3rd. Even if I shift it manually it won't give me 3rd. So, do we have any ideas on the problem?
Old Apr 18, 2016 | 10:15 PM
fuzzybob's Avatar
fuzzybob
Did you wire the kick down in the wrong direction???
Old Apr 18, 2016 | 10:16 PM
Nicktitan's Avatar
Nicktitan
No, it's default position is the Full Throttle setting, and I had to deal with that on the maiden voyage. That was the first problem I ran into, which is why I bailing wired it down so I would actually get a shift between 1 & 2 without having to give it full goose
Old Apr 18, 2016 | 10:23 PM
fuzzybob's Avatar
fuzzybob
vac mod hooked up with a good vac signal? The pin didn't fall out if you had the mod removed? I'm just spit balling here. Oil level to the full mark?
Old Apr 18, 2016 | 11:10 PM
Nicktitan's Avatar
Nicktitan
I'm going to replace the vac hoses and recheck the oil in the morning, but I never had the mod removed from the trans
Dr. Johnson
Nov 14, 2015 08:14 AM
greenbeast1
May 6, 2014 11:16 AM
406angler
Mar 3, 2014 04:49 PM
stoshmolcany
Jul 3, 2011 11:48 AM
68murc
Sep 12, 2007 05:45 PM
