Bad Vacuum Pump?
Old Apr 18, 2016 | 07:43 PM
Kingkong0192's Avatar
Kingkong0192
Bad Vacuum Pump?
Was sitting in a parking lot today and I noticed my brake light was on. Pulled the handle, nothing. Slowly dimmed off and stayed off.
I shifted the truck into reverse, rolled back, stepped on brakes, let off, repressed, let off, repressed. Brake light popped back on. I noticed about a week ago that I had little to no power brakes in reverse, but figured that to be normal. I'm thinking that's not normal now.
Seems to brake fine once you build some revs up though.
Another thing I noticed which may be irrelevant is my climate control selection doesn't really work. When I put it on max AC, full blast, it blows out the defrost. Occasionally it'll blow out vents but not often. Vacuum related?
Thanks!
Old Apr 18, 2016 | 08:02 PM
oldbird1965's Avatar
oldbird1965
You have a bad vacuum pump! If it was my truck I would change it out.
Old Apr 18, 2016 | 08:25 PM
Kingkong0192
Originally Posted by oldbird1965
You have a bad vacuuonor m pump! If it was my truck I would change it out.
OEM or aftermarket?
Any idea if A/C issue is related?
Old Apr 18, 2016 | 08:52 PM
ReBilld's Avatar
ReBilld
Originally Posted by Kingkong0192
OEM or aftermarket?
Yes, the climate controls and the brake booster work off vacuum, so I would say a new vacuum pump will fix both issues. And me personally, I would go OEM.
Old Apr 18, 2016 | 10:06 PM
farmert's Avatar
farmert
As stated, the AC/heater will default to defrost position with a faulty vacuum pump, regardless of where the control is positioned. The brake peddle will usually get very hard to push down, and stopping power is diminished, when the pump goes south.
Old Apr 18, 2016 | 11:04 PM
oldbird1965
So, where do you find a OEM?
Old Apr 18, 2016 | 11:16 PM
Kingkong0192
Appears Ebay has them for about a hundred bucks. Only problem is I'm at my uncles in Oregon and I'm not so sure he has a pulley puller but I'll ask him when I see him tomorrow. I reckon a local parts store might be able to help me out with that.
Thanks again guys! You rock!
Old Apr 18, 2016 | 11:47 PM
oldbird1965
Good to know.
Old Apr 19, 2016 | 07:47 AM
Jarrett Campbell's Avatar
Jarrett Campbell
I got my vacuum pump from Oreilly's and it came with a new pulley and bolts in place. Didn't have to use a puller thank goodness.
Whitman026
May 8, 2017 08:59 AM
kyle j
Apr 23, 2016 05:44 AM
stangdano
24
Feb 3, 2015 09:18 PM
masterc16
Jul 10, 2006 12:29 AM
smashing4455
13
Aug 11, 2005 05:42 PM
