Brake issue
Old May 8, 2017 | 12:33 AM
Whitman026's Avatar
Whitman026
Brake issue
Well I have a 92 F250 with a 7.3 IDI, The brake pedal is hard most of the time while driving but some times when I down shift or if I am in 5th gear for a long period of time I will get 1 shot of normal brakes. Also the Rear ABS light just recently came on. I am leaning towards the vacuum pump but I would like to get other opinions. I have already changed the brake booster check valve. Also the A/C isn't working and the heat is defrost only which points towards a vacuum issue. Got any ideas?
Old May 8, 2017 | 07:07 AM
tecgod13's Avatar
tecgod13
Vacuum issue...
either pump is bad, or you have a massive leak somewhere.
Old May 8, 2017 | 08:59 AM
cadunkle's Avatar
cadunkle
How much vacuum is it pulling under these conditions before and after applying brakes? Compare to vacuum directly off the pump.
Kingkong0192
Apr 19, 2016 07:47 AM
Duckkiller72
Oct 26, 2015 12:40 PM
joshofalltrades
May 16, 2013 01:53 AM
smashing4455
13
Aug 11, 2005 05:42 PM
Dieselman929
Jun 14, 2004 04:39 AM
