ABS motor fitting
Old Apr 18, 2016 | 03:27 PM
jberrouard's Avatar
jberrouard
ABS motor fitting
I have a 2002 F350 and I am changing all of my hard lines. I bought pre-bent stainless lines on ebay. I installed everything except the small line that goes from the ABS motor to the LF brake hose.
I must have cross threaded the line so i removed the fitting from the motor, tried a tap which just made it worse. I am thinking the only way I will be able to fix it is to buy a junk yard ABS motor and take it off of that but I wanted to see if anyone knew of where i could get a fitting first. I think the male is 1/2-13 and the female should be regular 1/8 pipe thread and it has a male flare inside.
F-ReV
Aug 9, 2018 03:43 PM
5.0 Heaven
1978 - 1996 Big Bronco
Sep 29, 2013 12:34 PM
krewat
Sep 6, 2011 08:24 AM
tswalls
1997 - 2003 F150
Jul 25, 2011 01:49 PM
r_b_burg
Nov 16, 2005 03:42 PM
