Seeking wisdom
Old Apr 18, 2016 | 08:16 AM
barrett74's Avatar
barrett74
Seeking wisdom
Need the name of this broken piece and any advise on how to go about fixing this problem. <br/>71 f250 4x4 3speed manual
Old Apr 19, 2016 | 07:17 AM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Try this Ford Lower Shift Bowl40 | Steering Column Services
Old Apr 19, 2016 | 08:57 PM
Jules The Great's Avatar
Jules The Great
Apart from replacing it you could try cleaning all the paint off and clamping it back together then use that aluminum brazing rod they sell at swap meets to fill it all back in and maybe add some material and then re-drill the holes? To make it even stronger you could also wire wrap it with aluminum wire from the base out to the holes and just past them THEN braze over all that with the aluminum rod and I bet it would be pretty strong. Same thing though just fill it and then re-drill and clean up the inside with a dremel.
DR Smith
Nov 15, 2016 02:10 PM
jrockdiddy
Nov 21, 2014 02:43 PM
berry1234
Paint & Bodywork
Sep 21, 2009 12:23 PM
Greg 79 f150
Garage & Workshop
Jun 13, 2006 07:23 PM
Oval_obsessed
Garage & Workshop
15
Jun 28, 2005 11:04 AM
