1978 - 1996 Big Bronco
89' Bronco Project
Old Apr 18, 2016 | 01:19 AM
FordOBS1989's Avatar
FordOBS1989
Smile 89' Bronco Project
EFI and AOD all failed to feel it happened all at once. So got a few questions. Still have the 5.0L 302 but I am Carburating it. I went with the C6 Auto Transmission with the NP-205 Transfer Case.. All out of a 78-79 Ford truck.. now I quickly realized that the 80-87 bronco never came with the NP-205 transfer case. It was the NP-208... oops... so here are the questions... about getting the NP-205 shift lever out of the original 78-79 shift lever for the four wheel drive. Basically trying to find out what other people have done.
- Drive shaft lenghs Front and Rear (Where to find them (hoping not for NEW))
- How to cut up the Floor Board for the 4wd lever
Old Apr 18, 2016 | 01:20 AM
FordOBS1989
Any pictures can be posted as requested.
Old Apr 18, 2016 | 06:37 AM
gatorfor88's Avatar
gatorfor88
78-79 4x4 trucks never came with a 302/351. They did come with a 351m/400 but this c-6 tranny wont bolt up to a 302. I dont think the 300 6 was offered in a 78-79 4x4 either but I dont remember. If it is a 2 wd c-6 that was behind a 302 it will have to be torn down and the correct output shaft and tailhousing for a transfer case adapter installed to work. So the shift lever, cutting holes in the floor, and driveshaft lengths are probably the least of your worries.
Old Apr 18, 2016 | 10:36 AM
FordOBS1989
C6 does bolt up to the 302.... I am just looking to see how the NP205 transfer case shift lever was ran.. it's been a while since I seen it. I have a access panel but not sure if I can get away with using that or having to cut into the transmission access cover than wanted to know if someone has done this before so if I can just get away with robbing some driveshafts out of a 78-79 bronco
Old Apr 18, 2016 | 10:44 AM
FordOBS1989
Old Apr 18, 2016 | 03:36 PM
gatorfor88's Avatar
gatorfor88
I know a c-6 does bolt up to a 302. I also know that a 302 was never offered in a 4x4 in 78-79. 2wd yes. 4x4 ,emphatically, no. And a 2 wd c-6 will not allow you to bolt up a transfer case with out tearing it down and modifying it. And I do know everything I stated to be factual and I am not going to argue with you about it. Good luck on your project.
Old Apr 20, 2016 | 03:44 PM
FordOBS1989
I know the 302 was not offered in the 78-79 bronco (I had one) but that's not my question. Was wondering if someone knew how much of a difference of the wheel base was to the 78-79 bronco and the 89 bronco... needing driveshafts... want to hopefully get some out of a 78-79 bronco if it will work and if the 4wd shift lever dimensions if I can get that hopefully? Trying to make this work as easiest as possible but it's not..
for46016
Feb 11, 2009 10:58 PM
rnp388
Mar 1, 2005 08:13 PM
tkyllo
Aug 13, 2003 04:44 PM
msautry
Nov 18, 2002 07:43 PM
PMD66
Nov 17, 2002 11:45 AM
