HELP. Stranded with Power Steering gone
Old Apr 17, 2016 | 07:28 PM
jed1894's Avatar
jed1894
I hope you guys can put me on the right track....here's the problem:
While turning very slow and sharp on the farm, I heard a pop under the hood. I then lost power steering and brakes. I saw power steering fluid spurting in the left tire well behind the tire. Look under hood and saw fluid coming from a fitting on the side of the power steering pump. I have attached a photo....one photo with nothing and then other with a screw driver tip on the fitting.
It appears that the the pressure fitting blew out the side when I turned sharp. It has a nut from which it came (compression of some sort?). I can push the nipple of the fitting back into the nut but I guess the pressure is gone. Before I screw something up, can you guys tell me what you think? Stand by for the photos
Old Apr 17, 2016 | 07:41 PM
clem1226's Avatar
clem1226
Only way to fix it is a new line. It has happened to me twice.
I disconnect the batteries, pull the driver side battery and the drivers side IC pipe as well as the air box.
It will take longer to fight it in if you leave all that stuff in place than it would to just bite the bullet and get everything out of the way.
F350-6's Avatar
F350-6
Common thing. Go buy a new high pressure line for the power steering pump and put it on.
jed1894's Avatar
jed1894
Photographs
Here are the photographs...
Old Apr 17, 2016 | 07:44 PM
jed1894's Avatar
jed1894
Thanks guys for the quick response. You guys are fast. Had the answer before I had the pictures up. It's dark now..... what's the other end of the connect to? Easy to get to?
Old Apr 17, 2016 | 08:24 PM
jed1894's Avatar
jed1894
I think I have the right part number from searching old thread on this site. If anyone has a minute and can verify before I order one, that would be great.
1C3Z 3A717 AA.
I assume all I need to do is hook it up and fill with fluid and away I go, right? Any suggestions on fluid, etc.
Thanks JED
Old Apr 17, 2016 | 11:06 PM
coax9952's Avatar
coax9952
Sorry, I can't validate the Part number, but it's a common part so you should be good. U might go to Ford .com and check for a schematic and you should find the latest part#. Reinstall, refill with Mercon V, start 'er up, work the air out of the system by turning the wheel back and forth a few times, Checking for leaks the whole time and you will be good. Also be aware that that's probably the high pressure side so, protect yourself....
Old Apr 17, 2016 | 11:19 PM
Tedster9's Avatar
Tedster9
Heck I dunno, Georgia is a pretty fur piece from here. I better pack a lunch. Is there anybody closer?
Old Apr 17, 2016 | 11:54 PM
AllaboutMPG's Avatar
AllaboutMPG
Pump to hydroboost is what you want to change since it's the one that always blows out the side of the reservoir.
Old Apr 18, 2016 | 03:05 PM
retiredsparky's Avatar
retiredsparky
If you are in a hurry, call the local ford dealer. They are more expensive, but close. If you have time, go to RockAuto.com. They are cheaper, but can ship overnight to you.
Old Apr 18, 2016 | 06:04 PM
countrycar's Avatar
countrycar
Autozon, Orielly's etc carry them as well for around 30 bucks.
Old Apr 18, 2016 | 07:45 PM
Tugly's Avatar
Tugly
I had one blow in the parking lot. First I dialed Ford, then I dialed my wife to bring the part. It took me longer to break out the tools, clean the mess, wait for the wife to show, and put away the tools than it did to fix the broken hose. Total time from splash-down to launch - two hours.
Old Apr 18, 2016 | 07:59 PM
crop harvester's Avatar
crop harvester
That's the same p/n that I bought recently,pump to hydroboost.
Old Apr 18, 2016 | 09:15 PM
jed1894's Avatar
jed1894
Thanks guys for all the post. I plan to order tonight if they can it here by weekend. If not, picking up at ford tomorrow. I will, as always, post a follow-up and let y'all know how it came out.
Old Apr 18, 2016 | 09:17 PM
jed1894's Avatar
jed1894
How do they compare to OEM? Dealer price around $110
