Trailer light's
Old Apr 16, 2016 | 05:46 PM
Preston Mallett's Avatar
Preston Mallett
Trailer light's
I just recently as of today signed up for the Ford Forum I have a 06 F250 5.4 liter 2 wheel drive that trailer lights are not working brand new connection for everything on the truck except for at the fuses I can't seem to find a form or a diagram since I lost my owner's manual to show me exactly would be the main one I would check. It's definitely not the trailer actually wiring hookup itself because all that was redone the trailer lights work on other trucks as well
Old Apr 18, 2016 | 01:50 AM
davester250's Avatar
davester250
google "ford f250 owner manual" the first hit will be for ford's site where you can download the right version for your truck.
Old May 18, 2016 | 03:22 PM
Travis S's Avatar
Travis S
Trailer light's
4 Pin or 7 Pin trailer connector? With an assistant, see if each circuit works by having them hit the turn signals, brakes, etc while you check the trailer connector with a test light or multimeter.
My trailer subharness was in poor shape after 20 years. Corrosion got into some of the wires and ate them from the inside. Had to splice in fresh copper and rebuild the 7 Pin connector with new terminals and screws. On the Trailer battery charge wire, it showed over 2000 ohms resistance. When I cut it, all that was there was blue fluff instead of copper.
tcobra66
All Things Towing
May 22, 2018 10:31 AM
DavidCarr
All Things Towing
Mar 23, 2015 07:56 PM
3505740
Jul 12, 2013 01:57 PM
MKRemi
6.7L Power Stroke Diesel
22
Apr 12, 2012 07:48 PM
Ruikee
All Things Towing
Jun 8, 2008 07:35 PM
