6.2L V8 Discuss the 6.2L V8
Engine Cleaning
Old Apr 16, 2016 | 10:10 AM
Squisher's Avatar
Squisher
Engine Cleaning
Now I'm a bit of a neat freak and like to keep my ride shiny inside and out. Having a 99 7.3 and 03 5.4 I have learned to never pressure wash under the hood. But I'm wondering if water intrusion is as much of a problem on the newer trucks, specifically the 6.2. My engine compartment is getting dusty/dirty and I'm dying to spray it down. But not so much so that I want to risk electrical gremlins.
How, if at all are y'all cleaning your engine bays?
Old Apr 16, 2016 | 10:28 AM
GSSF17's Avatar
GSSF17
I hose mine out with a moderate spray of water only (what I would call a firm, direct mist), without any direct, continuous spray or hard spraying on any electrical connections/components. I wipe areas down that I can reach with a cloth afterward. Keeps things looking nice.
I have done this periodically since I bought the truck in 2012 and have not had any problems.
Curious for others to chime in.......
Old Apr 16, 2016 | 10:50 AM
don123's Avatar
don123
I've rinsed my motor off with a garden hose a few times because it was full of salt and dirt. Cleaned up real good with hose then I wiped it all down with a rag. Started right up no problems. Just be careful around electrical areas. Obviously I cleaned it when the motor was cool.
Old Apr 17, 2016 | 11:04 AM
Squisher's Avatar
Squisher
Cool. Thanks for chiming in. I guess gone are the old days of spraying some cleaner on and then just giving her with the pressure washer with the carb and the alt covered. Lol.
Old Apr 17, 2016 | 09:02 PM
R Guest's Avatar
R Guest
Get some Simple Green and head to the pressure washer. Ive used Simple Green for years and works great on plastic and hoses. Never had a problem using a pressure washer on any of the cars we have owned over the years.
Old Apr 17, 2016 | 10:22 PM
fordmerc's Avatar
fordmerc
I like to spray the engine down with a degreaser and use a pressure washer on it on the lightest spray setting. Before I start it, I use compressed air to dry all the critical areas.
I know the engines I'm dealing with aren't as complex as what you are talking about, but it has worked for me.
Old Apr 18, 2016 | 09:15 AM
wrvond's Avatar
wrvond
I use the same bucket of car washing soap and microfiber mitt I use to wash the rest of the truck. I do the engine compartment last. I don't use high pressure, just enough to rinse all the soap off, then I dry with a towel to avoid spots.
You do want to avoid soaking the pad on the hood, they disintegrate rather easily.
Old Apr 25, 2016 | 11:36 AM
Luco13's Avatar
Luco13
I use a simple degreaser/simple green as well. Spray on and rinse off with a light spray from the pressure washer. Looks like new after many off road trips.
shockr4
2004 - 2008 F150
Feb 15, 2014 08:37 PM
EXbowtieguy
Oct 25, 2011 11:16 AM
ace555
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Jul 17, 2008 09:23 PM
ctboyle03
1983 - 2012 Ranger & B-Series
Jan 21, 2007 07:40 PM
baboren
Garage & Workshop
37
Jul 26, 2003 08:25 PM
