Need another part number - 5R110W TSS
I need the transmission speed sensor for my truck and I am getting a confusing array of Motorcraft and Ford part numbers. I have Motorcraft numbers DY1251 (Turbine Shaft Speed Sensor Assembly) and DY1229 (Transmission Speed Sensor). Not sure what the difference is between the two.
I've been having a recurring problem where, when my speedometer starts wavering, the truck will sometimes jerk, like maybe it's trying to down shift or a stumble of some sort. I've replaced the VSS in the rear diff (with Motorcraft) which cleared up the worst of it, but this problem still persists.
I don't have your cover so I can't say. I've seen a number of cases where the sensor collects enough iron debris to screw up its ability and gives an inconsistent reading. While I realize it's a long shot, I would do it just to eliminate the possibility and check off the box.
Even if the plug was magnetic, my typical inspection has shown a much larger accumulation of debris in the bottom sump of the differential housing, enough that when we changed fluid on vehicles I made sure there a good effort to get all of the muck out of the housings bottom.
Again, maybe not your issue but it's a no cost item to check, one that has a history.
xraytommy93
11-10-2003 03:21 PM
