Air Fuel ratios with carburetors
What I'm reading is slight adjustments of the idle mixture screws makes big changes in the A/F ratio, though not enough so you'd hear it. That's probably why they put limiters on them at some point. Whenever there is any kind of engine trouble the first thing people used to do is bugger with the carb, probably because it's conveniently located. Never mind that it's rarely at fault. Radio repairman used to run into a similar issue when listeners at home would "tighten all those loose screws" on the tuning capacitor. Oops!
Timing comes into play, or ignition advance changes A/F drastically correct?
One thing I don't understand, though it doesn't necessarily apply to these particular beasts, is why ignition timing that is retarded reduces hydrocarbons at idle. 70s smog era rigs, the manufacturers went through all these contortions and contraptions to detune the engine, and then burn all the waste after the fact. Apparently a well running, advanced timing engine has low HC, but a high level of NOX, which contributes to the reddish smog seen over cities in the past or where people still have jobs.
This makes no sense to me in the first place because "slow" timing means unburned fuel is being lost out the tailpipe. It's one reason why manifolds will start to glow, although excessively lean mixtures can melt things as well.
underthebridgejim
11-18-2016 12:08 AM
wantaford
02-11-2008 02:13 PM
HT32BSX115
08-07-2005 07:56 PM
