87 F150 Steering issue.... ??
Old Aug 13, 2003 | 03:19 PM
Katmandu2's Avatar
Katmandu2
Just picked it up last night and noticed on the drive home that the front end "Wallows" all over the place.
There's no real "Slop" in the steering wheel, but when inputs are given, the steering responds VERY slowly and overexagerated (if that makes sense).
Kinda "FLOPS" from side to side and when a "correction" is given, it OVER corrects.
The last vehicle that I owned that acted like this was a 77 K5 Blazer that had worn out front leaf springs.
I know the shocks are toast on this F150, but I think the problem is more involved than that.
Would stuck calipers (both) cause this problem ??
Old Aug 13, 2003 | 04:04 PM
gasman6674's Avatar
gasman6674
Worn or misadjusted steering box, worn out tie rod ends, bad ball joints etc. all can cause mystery steering. You need to put in on a lift an go thru it completely. My truck had a stuck caliper and it pulled to one side and made grinding noises
Hope this helps
Old Aug 13, 2003 | 08:41 PM
Incommunicado's Avatar
Incommunicado
Tie rod ends and the center link are fairly common problems jack it up and then shake the wheels from side to side, and you should be able to locate the problem
Old Aug 13, 2003 | 09:58 PM
c96drumm's Avatar
c96drumm
Also make sure the steering box attachment bolts are tight.
Old Aug 13, 2003 | 10:33 PM
FordBoypete's Avatar
FordBoypete
Katmandu2
Consider this, Steering is a matter of transplanting the footprint of a vehicle in motion. IOW, aim where one wants a vehicle to go.
In addition, strg wheel should center up on the return.
For all this to happen, caster, camber, & toe in must focus, or come together at a theoretical point established ahead of vehicle. When all is right, vehicle will aim for that point.
Okay, what's happening, from what you describe, is vehicle falls into & off of its' theoretical center. I bet a set of properly inflated, front tires, & a good front end alignment done by a qualified shop or dealership will corect your problem. Fbp
Old Aug 14, 2003 | 05:12 AM
Katmandu2's Avatar
Katmandu2
Yea, that's what it seems to be doing.
After I return the wheel to Center, the tires/linkage seem to be still pointing in the direction they where pointed at.
It's kinda like the Steering Components are Moving in Super Slow Motion to the Steering wheel inputs.
Old Aug 15, 2003 | 05:40 AM
Quarterhorse's Avatar
Quarterhorse
check balljoints they could be frozen...that happend to me~~~
Scoob5555
May 11, 2021 09:33 PM
midsouth
Aug 9, 2015 04:24 PM
pbjosh
15
Apr 25, 2015 03:49 PM
nanuke1
Sep 1, 2004 09:09 PM
km74
Dec 22, 2003 02:42 PM
