Front end issues
Old Aug 9, 2015 | 08:45 AM
midsouth's Avatar
midsouth
Front end issues
On my 83 f150 4x4 5.8 liter pickup, the truck is all over the road. If the truck hits a bump on the right, it heads to the right and the truck bounces, causing difficulty in steering...I'm constantly correcting the steering to stay on the road. The steering box is newly replaced. I've also put on new shocks which were the correct fit from my local parts retailer. Any suggestions?
Old Aug 9, 2015 | 10:23 AM
fordtruckguy98's Avatar
fordtruckguy98
I would look at the tie rods and ball joints. sounds like they are badly worn that's how mine was when they where bad.
Old Aug 9, 2015 | 12:24 PM
midsouth's Avatar
midsouth
If I find the ball joints to be bad, once replaced, would I have to have the front end aligned?
Old Aug 9, 2015 | 12:45 PM
Tedster9's Avatar
Tedster9
I think if the mechanic is careful and counts or measures threads on most any of the front end parts it will be fine, assuming alignment is good now. Don't quote me on that though.
Old Aug 9, 2015 | 04:24 PM
Franklin2's Avatar
Franklin2
Take it to get it aligned. They should check before they do the alignment. Then they will come back and tell you what it needs before they can align it. If it's the balljoints, get ready for a very large estimate to fix it.
Jeff heine
Aug 19, 2023 09:42 AM
Njstern87
Apr 24, 2018 06:43 PM
rookieford
Feb 15, 2016 08:56 PM
Docdor
Nov 3, 2010 08:52 PM
KTM Mike
Jul 22, 2007 03:25 PM
