Odd bucking behavior
Old Apr 20, 2016 | 07:37 PM
g2gnospam's Avatar
g2gnospam
Looking more closely, it appears that I do have the rear of the axle mounted monster tank that is steel. Wondering if there are plastic replacements for this tank as I have heard of the internal coating breaking loose, etc.
Old Apr 24, 2016 | 04:41 PM
g2gnospam's Avatar
g2gnospam
Originally Posted by Tugly
My first thoughts went to the CPS and the IPR. One of those is free to check, the other is inexpensive to swap out as a precaution. I then have to ask if the engine sounds "knocky" when under load. If so, one or more loose injectors can make the engine sound more knocky, cause bucking, and pop the SES light because of ICP bleed. A quick look at the fuel filter to see if it's black may point to this.
Finally can see the top of the motor (very tight in the front of a van). Fuel filter pre-screen was pretty dirty (fine particles). ICP is definitely the old style and has the oil leaking through the connector wires. IPR "looks ok" not sure if it has the tin nut (how do I tell?). CPS will be changed at the dealer do to recall on Wednesday.
Old Apr 24, 2016 | 04:55 PM
g2gnospam's Avatar
g2gnospam
BTW. The engine starts right away and idles well. Also seems to be a bit rough running at 40+ MPH. Just also did an oil change, etc. Added Archoil AR9100, but will not road test until I replace the ICP.
gascan
Oct 24, 2016 09:12 AM
FordGirl2009
2009 - 2014 F150
Jul 28, 2015 04:07 PM
diesel soot
13
Aug 2, 2011 11:06 PM
dbcooper02
Aug 20, 2007 03:32 PM
kkl
3.8 & 4.2L V6
21
Oct 27, 2003 08:58 AM
