Dash board pieces
Old Apr 12, 2016 | 06:04 PM
Oilfield Trash's Avatar
Oilfield Trash
Dash board pieces
I am looking for a few pieces of my dash. I have tried the salvage yards around here and looked online. eBay hasn't provided me with what I need yet. Does someone have a part number for the bezel around the radio and the panel around the defroster switch? I would love a blank for the defroster as I have plans for this area. I will eventually go to the dealer if I need to.
Old Apr 12, 2016 | 06:19 PM
Matt M, PA's Avatar
Matt M, PA
The dash bezel is long disco-ed by Ford.
If memory serves, the rear defrost switch area (the flat spot around the defrost switch) is snapped in and varies depending on the options your truck has.
Also, while an SD part may fit (they're used on eBay) they have the air bag shut off area that Exs don't...
Old Apr 12, 2016 | 07:30 PM
Jeremy05's Avatar
Jeremy05
2003 and 2004 King Ranch f-250/350's use the same bezel style as the excursions. That may help you in your search.
Old Apr 12, 2016 | 07:34 PM
Oilfield Trash
Thanks for the information I'll keep up the good search
Old Apr 12, 2016 | 09:01 PM
pkthomas's Avatar
pkthomas
I think I have a defrost switch in tan. You can have it, if I can find it.
Old Apr 13, 2016 | 05:55 AM
05MilMachine's Avatar
05MilMachine
Whatever they made these bezels out of is turning out to be some brittle garbage. Thankfully mine is black and matches JB quick weld quite nicely. I think the biggest issue with a replacement is loosing the Excursion badge, so I repaired mine.
Old Apr 13, 2016 | 06:33 AM
Matt M, PA's Avatar
Matt M, PA
The badge comes off. It's on a thin piece of metal with an adhesive. I think a tab goes into a slot on the back. I pulled mine when I painted my dash bezel and put it back...
Old Apr 13, 2016 | 07:37 AM
05MilMachine
The f250 dash doesn't have the recessed area for it to sit in. You could make it work but it would look different.
Old Apr 13, 2016 | 09:02 AM
Oilfield Trash
Would be nice if some company started manufacturing them in Oem colors. I think B&I does the wood grain. I believe it's only select pieces. The website is not mobile freindley
Old Apr 13, 2016 | 09:15 AM
Jeremy05's Avatar
Jeremy05
There is a king ranch one on ebay, but you'll need a excursion window defroster switch.
http://m.ebay.com/itm/SUPER-DUTY-F250-F350-KING-RANCH-DASH-RADIO-GAUGE-CLUSTER-BEZEL-02-03-FORD-/252347740778?nav=SEARCH
And an excursion one, but not a 2x4 so you'll still need that switch panel
http://m.ebay.com/itm/00-01-02-03-04-05-FORD-EXCURSION-F250-RADIO-CLUSTER-DASH-BEZEL-PANEL-SWITCH-4X4-/281991337364?nav=SEARCH
Old Apr 13, 2016 | 02:47 PM
jpr38057's Avatar
jpr38057
Part # for medium dark parchment is YC3Z 25044D70-BAA. A place called Vintage Parts Vintage Parts - Your Service Parts Inventory Partner shows to have 7 of them. It retails for $84. This is a genuine Ford part. Vintage Parts buys obsolete inventory from Ford.
outofcontrolreb
Apr 23, 2019 03:38 PM
ItsAFord55
Apr 2, 2012 09:09 PM
rmalottwtes30
Dec 19, 2008 10:50 PM
DAFBFD58
Aug 13, 2008 08:31 PM
Billinvancouver1
Nov 12, 2007 03:01 PM
