Powering up reading odometer
Old Apr 12, 2016 | 02:33 PM
JRS2's Avatar
JRS2
Ok, wonder if anyone knows how to supply power to an instrument panel such that the odometer mileage can be viewed, without having to disassemble your good vehicle and plug it in ? For instance having knowledge of the pinouts going to the actual speedo does data come back from computer, or is data stored in the actual speedo assembly ?
thks
Old Apr 12, 2016 | 03:48 PM
rla2005's Avatar
rla2005
The odometer mileage is stored on the PSOM.
You can power up the PSOM using a 9V battery. Post# 4 in this thread: https://www.ford-trucks.com/forums/1...n-cluster.html
Courtesy of Subford
Old Apr 12, 2016 | 05:01 PM
JRS2's Avatar
JRS2
Thanks I had a feeling someone might have already figgerd this out ....
If i have any followup questions will be sure to ask ...
Old Apr 12, 2016 | 05:23 PM
rla2005's Avatar
rla2005
Bill has a jig for pretty much everything on these trucks..
Old Apr 12, 2016 | 10:10 PM
JRS2's Avatar
JRS2
Ok, for my immediate need pulled apart my good unit and plugged in two of my resale units to get an odometer check, worked just fine except I broke a bracket which apparently is time to replace. One other question the 92-93 are supposedly different from 94-95. Are certain gauges simply not compatible between years ? Will the speedo interchange between these years ? In case you know.
Thks again.
TheKirbyMan
39
Sep 1, 2019 04:12 PM
coreylasalle
Apr 2, 2014 08:34 PM
colorado solar guy
Aug 8, 2008 07:16 PM
chewyjackson
Sep 22, 2006 08:03 PM
