95 F 350 DOOR LATCH ?
Old 04-10-2016, 09:18 PM
v860rich
v860rich is offline
v860rich is starting off with a positive reputation.
95 F 350 Crew Cab---Rt rear outside door button will not unlatch door.
I pulled door panel and found the rod that goes from the handle down to the latch unattached at the button end. The only place I see to place the upper end of this rod is a white plastic piece that's captured in the handle assy.
I had to move the rear window channel to install the rod end in the plastic but don't see how it is held but that might not be a problem as the latch will still not release with the outside button.
Is there some place to find a parts breakdown on this?
Also a couple of the window motors do not engage the regulators properly and only allow the windows to go down by gravity and go up with my help.
How are the motors removed from the doors? It looked to me that there are some sort of rivets holding them in.
THANX RICH
Old 04-12-2016, 05:22 PM
rla2005's Avatar
rla2005
rla2005 is offline
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
I found this diagram from Fordparts:
As far as the power window functions goes, it's very common for the spacers to wear down. There is a kit from Dorman to replace them or some have used 1/4-20 nuts. There is a write-up around here some place...
Yes, the motors are held in with rivets, drill them out then replace with screws and nuts.
Old 04-12-2016, 10:22 PM
v860rich
v860rich is offline
Thanks for the diagram.
I ended up finding a video on u tube on fixing the power window motors and how to remove the door handle.
I now have 3 of my doors almost finished, going to try and find a couple of the factory type rivets to finish up the rt rear motor, I've used bolts on most of the places I drilled out the factory rivets but 2 of the holes I can't get my hand behind to insert bolts.
I got the door button linkage hooked back up and that works fine.
One thing I find strange is that this truck has power door locks but only on the front doors.
My 89 Chevy crew cab has power door locks but on all 4 doors.
Going by my Chevy I just figured this had p/locks on all doors, come to think of it there are a couple of Jeeps around here that are 4 door and they both have p/locks on all doors!!!
THANX RICH
ExxWhy
01-28-2019 12:53 PM
got2bjoester
Escape & Escape Hybrid
04-11-2017 06:16 AM
annaleigh
1968-2013 Full Size Vans
05-06-2016 05:51 AM
teched
04-05-2016 02:46 PM
baverwolf
03-14-2016 01:46 PM
Quick Reply: 95 F 350 DOOR LATCH ?
Contact Us - About Us - Archive - Advertising - Cookie Policy - Privacy Statement - Terms of Service
