Intermittent starting problem... Help a Vet out...
Vehicle is a 1999 expedition 5.4L, on occasion the vehicle won't start, it wont even turn over. I have to pop the hood and jump the starter relay on the fire wall and then it runs. I had the starter checked and it was good, the starter relay on the fire wall is also new and I also replaced the battery cable harness. I'm thinking its the ignition switch but not 100% sure. Any ideas?
Do you have slop in the shifter ? You may have an issue with not going into park properly . The neutral safety switch may be faulty also . Just a few thoughts ...
If that's the case I should be able to put it in neutral when it doesn't start to start the vehicle?
Yes, or another method is (with your foot on the brake) to reach over with your left hand and hold the key in the start position while moving the shifter down with your right hand until you hear the starter engage.
