P1744
Old Apr 12, 2016 | 08:59 AM
outoforder's Avatar
outoforder
P1744
The OD light started flashing and I'm showing a P1744 code (Torque Converter Clutch stuck in off position, excessive slippage). The truck still seems to be shifting fine. Even when OD light is flashing, I can still turn OD on/off and feel the torque converter lock and unlock. I checked the pan temperature over the weekend with an infrared thermometer and it was 150 degrees. I was told by a friend that actual transmission temperature is 10-20 degrees higher than pan temperature. Any truth to this? Local transmission shop told me I needed a rebuild. In my semi-informed opinion, if transmission temperatures are reasonable and the truck is shifting ok, the transmission still has some life left in it. Thoughts?
Old Apr 12, 2016 | 09:44 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
Try clearing the code and see if it comes back. It might have been a one time anomoly.
Old Apr 12, 2016 | 09:51 AM
outoforder's Avatar
outoforder
Old Apr 12, 2016 | 09:55 AM
outoforder's Avatar
outoforder
Cleared the code, but it came back.
Old Apr 12, 2016 | 02:12 PM
Mark Kovalsky
Then you do have a problem. It could be a worn out converter clutch, a damaged seal on the input shaft, a sticky valve in the pump body, or a bad torque converter clutch solenoid.
greabr
Oct 23, 2024 02:41 PM
dieselsubmariner
Nov 25, 2018 08:58 AM
350Fitter
May 3, 2018 08:28 PM
F150vettehauler
2004 - 2008 F150
Jun 21, 2014 06:31 PM
msmenne17
Apr 13, 2012 02:23 PM
