1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
key fob ??? cant find the answer
Old 04-10-2016, 07:56 PM
chaser1602's Avatar
chaser1602
chaser1602 is offline
04 f350 lariat Key fob slowly started not to work until it finally quit. Thought it was the battery but changing it had no change. Do the fobs go bad and need to be replaced?
Old 04-10-2016, 08:22 PM
dscabra's Avatar
dscabra
dscabra is offline
Silly question -- Are you sure the new battery is good?
Old 04-10-2016, 08:28 PM
chaser1602's Avatar
chaser1602
Well I did but it today. I know it couild be bad. just thought of that
Old 04-10-2016, 08:34 PM
dscabra's Avatar
dscabra
dscabra is offline
If your second fob is working, try swapping the batteries with the one that isn't working and see what happens.
Old 04-10-2016, 09:09 PM
chaser1602's Avatar
chaser1602
only have 1 fob
Old 04-10-2016, 09:21 PM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
I've been going through the same problem with my 2004, fobs worked the started to act up. Bought new batteries then a brand new key fob, about three weeks later new key fob quit. Installed another new battery and no go my buddy is the parts manager so he replaced my three week old fob, worked for a week now today the brand new fob stopped working! I checked the battery and it's good so I tried to synch the fob to the truck and NOTHING I'm 100% convinced it's whatever controls the key for inside the truck is the problem because everything else is brand new
Old 04-11-2016, 08:25 AM
Last_Stroke's Avatar
Last_Stroke
Last_Stroke is offline
Sounds like a key fob to me, I ordered two new key fobs off Amazon for i want to say under $10. It takes longer to unbox it then it does to sync them to your truck. I would say give that a try for a inexpensive "test"
-Last_Stroke
Old 04-11-2016, 08:49 AM
phillips91's Avatar
phillips91
phillips91 is offline
I had the same problem with my fob for my van. It worked some days and wouldn't on others. Sometimes I had to press it really hard and stand in a certain place beside of the door. Other days it would work from 20 feet away.
Old 04-11-2016, 04:50 PM
xd2200's Avatar
xd2200
xd2200 is offline
I have never had my SD key fob apart but just did my 2005 Buick LaCrosse. There is a membrane that goes between the circuit board and the top cover. This membrane does wear out (and thus exhibits intermittent performance.) On EBay you can find replacement membranes for $10. For Buick you must have replacement fob programmed at dealer or by a locksmith so the membrane is a good deal. The other weak point on a fob is the battery holder. It is glued to the circuit board (via 2 pins) and has one solder connection. If glue comes loose solder connection is easily broken.
Old 04-12-2016, 01:15 AM
davester250's Avatar
davester250
davester250 is offline
The FOB I bought off ebay had a cheap battery holder/positive contact, so it wouldn't get powered properly. I could bend the contact so it would work for awhile, but it would fail again after some time. I'm considering soldering in a new, better contact/battery holder.
Old 04-12-2016, 05:51 AM
Last_Stroke
Old 04-12-2016, 05:58 AM
SuperDutyScaler
Not to high jack but I have two brand new Ford fobs and brand new Duracell batteries and my fobs only work when they want too...I still say it's what's inside the truck that is the problem
Truckpilot1329
2015 - 2020 F150
07-24-2022 11:57 AM
8e3k0
6.7L Power Stroke Diesel
12-30-2017 04:59 PM
cmalley12
6.4L Power Stroke Diesel
12-03-2012 08:29 PM
05superv10
Electrical Systems/Wiring
12-31-2008 12:19 PM
Quick Reply: key fob ??? cant find the answer
