key fob
Old Dec 27, 2008 | 10:14 PM
05superv10's Avatar
05superv10
key fob
quit working and just replaced battery still doesnt work. worked just fine till other day truck is 05 f250 sd with v10
Old Dec 28, 2008 | 04:09 PM
Franklin2's Avatar
Franklin2
If you have an owners manual, it should describe this procedure. Turn the ignition key on and off 8 times, I think the door locks will cycle, and then push any key on the key fob. See if that fixes it.
Old Dec 30, 2008 | 12:44 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
I think you have to reprogram the FOB once you remove the old battery..... like he says above....
Old Dec 30, 2008 | 02:11 PM
brian42's Avatar
brian42
Veteran: Navy
The fob should still work after you change the battery. If not, reprogramming it should do the trick. If that still doesn't work, your new battery may be dead.
Old Dec 31, 2008 | 12:19 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
...and are you SURE you installed the battery the correct side up?
