need help diagnosing
Old Apr 10, 2016 | 11:35 AM
jbrax's Avatar
jbrax
So usually when its hot my excursion idles wierd. It will idle like 1000 rpm then fall n it will b all over the place but it doesnt do it consistently. Sometimes not for a couple days. Sometimes when im at a red ligh on the brake it will idle up n wanna pull . Also if i get on it n floor it it will take off then kind of hesitate at high rpm. my edge showed a code for cylinder 5 but the shop hooked it up to computer n injecters tested fine. N then somedays it jus runs perfect. So all n any help or input will be greatly appreciated.
Old Apr 10, 2016 | 01:37 PM
BLADE35's Avatar
BLADE35
you need gauges to see what Value changes when this Happens
Could be Sensor turbo HPO system
When was the Last fuel filters done
Old Apr 10, 2016 | 02:08 PM
jbrax's Avatar
jbrax
Filters done 5000 miles ago. N do have gauges
Old Apr 10, 2016 | 02:35 PM
Yahiko's Avatar
Yahiko
Benny is talking live data gauges. ICP IPR MAF VGT IAT IAT2 EOT ECT
and a few others.
When I have some time later tonight I can pull the PC/ED book and look
at the testing that needs to be done if I can find a problem that matches
what you telling us. But please keep posting about what you have done and
found. The more info the better the chance of finding a fix.
Sean <BR>
6.0L Tech Folder
Old Apr 10, 2016 | 06:05 PM
jbrax's Avatar
jbrax
Yea i have n edge insight. Every once in awhile on cold start ficm will b low 40s til i start driving then its fine. Also at wot ipr will b 90 % but icp is only low 2000s. Anything else to look for?
Old Apr 10, 2016 | 07:33 PM
mhoefer's Avatar
mhoefer
You need a new FICM, if it is running less than 45 volts, when cold, call Ed at FICMRepair. It's possible there are other issues but I would start with that. This likely what is messing things up and why it is intermittent.
Old Apr 10, 2016 | 07:46 PM
m-chan68's Avatar
m-chan68
I agree. Your FICM is in need of replacement or repair. Also, what is your ICP DESIRED data, compared to your ICP ACTUAL under the exact condition you've described above? That almost sounds like your HPOP is weak as well by the numbers given.
Old Apr 10, 2016 | 07:47 PM
BLADE35's Avatar
BLADE35
But it Looks like you need a FICM and HPO Work and maybe alt or Batterys but lets see what it shows
your numbers were not tested correct Im talking HPO numbers
Take the HPO numbers with hot truck A/C off in Park
for ICP and IPR%
a Reading for both at Idle
ALSO
A reading for BOTH at 2500rpm
Do the same for FICM except Cold Truck
same at Idle and 2500rpm Get
FICM MP
FICM LP
FICM VP
VOLTS
Old Apr 10, 2016 | 07:50 PM
BLADE35's Avatar
BLADE35
He may have a Bad ICP sensor
so post ICPV @ KOEO
Old Apr 10, 2016 | 08:01 PM
white Buffalo's Avatar
white Buffalo
FICM main volts
FICM logic bolts
FICM Vehicle volts
Battery Volts
If you can data log with the edge - you can e-mail me the file and we'll graph it up to get a clear picture:
Old Apr 10, 2016 | 08:02 PM
jbrax's Avatar
jbrax
When its hot and in park and it start idling iratic . Ipr will creep up too at its highest like 35% while icp will be in the 600 n sometimes drop into 500s
Old Apr 10, 2016 | 08:04 PM
jbrax's Avatar
jbrax
@ 2500 rpm its around 50% and around 1600psi
Old Apr 10, 2016 | 08:12 PM
BLADE35's Avatar
BLADE35
you have HPO Problems NO Doubt
So check ICPV at KOEO (Key On Engine Off)
HOPE its in the .18-.24V range
Old Apr 10, 2016 | 08:23 PM
jbrax's Avatar
jbrax
Icp voltage says .2. I never did data logging on this edge yet. So let me look and see if i can figure it out. If not tonight thrn ill do it tomorro. Sorry, tired of banging my head off of this thing for the past 2 weeks with no luck whats going on. Thanks for all the help so far.
Old Apr 10, 2016 | 08:56 PM
BLADE35's Avatar
BLADE35
.2v shows good sensor
your HPOP is weak
your doing all this testing in stock mode right
for best diag truck must NOT be Tuned or as close to stock as possible
