E4OD Tranmssion Replacement brand choices
I need to replace my E4OD Transmission. It's in a 97 F350 Supercrew 7.3 Diesel with single Car hauler bed. I see many choices out there. ANy preferences on brands? I found some choices below from this forum and on line.
Monster
ATS
BD Power
Racer X
BTS
Monster
ATS
BD Power
Racer X
BTS
I can't give you long term results, but these folks worked with me to build a Level 3 enforcer with my stock high stall converter & upgraded many internals to 95-up for about thirty-five hundred. They have many kits for DIY & they ship complete units.
E4OD, 4R100 Transmission from PATC, E4OD, 4R100
^^ PATC is one of the places I bought parts from also.^^
I kind of went nuts with mine.
Here's a list of most of the upgrades I did.
ATS Billet Input shaft: http://www.atsdiesel.com/ats2/produc...p?p=3049103104
ATS Billet Intermediate Shaft: http://www.atsdiesel.com/ats2/produc...p?p=3049203104
TCS Billet Forward Drum: http://tcsproducts.com/products/prod...d-clutch-drum/
Center Support machined for snap ring: http://www.ebay.com/itm/271417456108?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Steel 6 Pinion Rev Planet: http://www.ebay.com/itm/200935513914?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
45 Element Intermediate Sprag: http://www.ebay.com/itm/371094777308?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Overdrive Spiral Snap Ring: http://www.ebay.com/itm/271647736899?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Intermediate Band Apply Servo: http://www.ebay.com/itm/371094777660?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
PowerTow Shift Kit Fairbanks: http://www.ebay.com/itm/270833991321?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Red Eagle Kolene Powerpack Rebuild Master Kit: http://www.ebay.com/itm/271513888111?_trksid=p2057872.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Four Pinion Steel Overdrive Planet,6 pinion steel forward planet gear kit,Teflon Coated Pump Gears,Hardened Shell, all picked up here: E4OD, 4R100 Transmission from PATC, E4OD, 4R100
Precision Industries Triple Disk TC.
I can't have my truck down for 3 months so i may have to explore other options you guys mentioned as well.
I won't be buying parts from ATS. New discovery yesterday. I bought a trans cooler and T stat last week and discovered they repackaged Derale product and marked it up 100%. I promptly returned and bought the Derale for less.
My build was 2 weeks Feb, last year. I dropped off & picked up. Don't know if that's an option for you.
PATC talks about a hot-shot & ambulance co's that uses their builds somewhere on their site.
They started as a straight rebuilder & branched out to high performance later on. They're not just hot rod parts shipper.
Center Support machined for snap ring: http://www.ebay.com/itm/271417456108...%3AMEBIDX%3AIT
Steel 6 Pinion Rev Planet: http://www.ebay.com/itm/200935513914...%3AMEBIDX%3AIT
45 Element Intermediate Sprag: http://www.ebay.com/itm/371094777308...%3AMEBIDX%3AIT
Overdrive Spiral Snap Ring: http://www.ebay.com/itm/271647736899...%3AMEBIDX%3AIT
Intermediate Band Apply Servo: http://www.ebay.com/itm/371094777660...%3AMEBIDX%3AIT
PowerTow Shift Kit Fairbanks: http://www.ebay.com/itm/270833991321...%3AMEBIDX%3AIT
Red Eagle Kolene Powerpack Rebuild Master Kit: http://www.ebay.com/itm/271513888111...%3AMEBIDX%3AIT
Quite true, and while BTS definitely has the upgraded internals and top notch frictions and steels, I doubt they use billet shafts.
hans88
01-04-2006 03:30 PM
