Wheels and Tires
Old Apr 7, 2016 | 10:00 AM
Bruinzfan's Avatar
Bruinzfan
Wheels and Tires
Hi All!
I am going to put factory 18"s or 20"s on my Excursion. I have the Modded C's rear and the V's up front. I leveled off the front with a 2" shackle to the rear of the leaf. I may change to X's this summer but that remains to be seen. ($$)
Given this set up can anyone definitively tell me if the 20"s will fit or should I stick with the 18"s? I am aware of the offset issues with the newer wheels. I have the hub centric wheel adapters on the way.
Thank you all!!
Keith
Old Apr 7, 2016 | 10:04 AM
harley4jcs's Avatar
harley4jcs
The wheel size does not matter at all ( unless going smaller & the brakes do not fit ) Only the off set (back spacing) & the TIRE size will come into play.
Old Apr 7, 2016 | 10:13 AM
holeshotwalt's Avatar
holeshotwalt
The question is only how tall of a tire do you want? The wheel diameter doesn't matter (to a point)!
I put 33x12.50-20 on mine with stock suspension @85k miles, and the only (minor) rub I had was at full lock on the spring.
So as long as you have the backspacing corrected with the spacers, you'll be able to go with a 34-35" tire for sure.
Old Apr 7, 2016 | 10:55 AM
mecdac's Avatar
mecdac
Exclamation
IMO, I would not go with factory 20" on your set-up (snowplow).
20" requires spacers, spacers will put additional stress on the wheel bearings (primarily front).
The weight of the plow and additional stress of the weight (and where it is distributed) on spacers = PROBLEMS.
Old Apr 7, 2016 | 11:06 AM
harley4jcs's Avatar
harley4jcs
EVEN THOUGH I agree fully with no spacers. I don't like them for such a heavy truck. He's adding Summer tires SO I don't think he'll keep the plow on ??
Old Apr 7, 2016 | 11:17 AM
mecdac's Avatar
mecdac
Wink
Originally Posted by Bruinzfan
Hi All!
Thank you all!!
Keith
Unless I am blind (possibly) I read nothing in the OP about summer tires.
Old Apr 7, 2016 | 12:29 PM
harley4jcs's Avatar
harley4jcs
PRE-POSTED.....Apparently he has received the management's approval
Old Apr 7, 2016 | 12:43 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
I'm pretty sure he runs snow tires on the stock 16's in the winter like I do. I could be wrong but I think I read that previously. So I think this would be a summer only thing.
EDIT: Somebody else already pointed this out, i just skimmed...my bad.
Old Apr 7, 2016 | 01:24 PM
Bruinzfan's Avatar
Bruinzfan
Summer tires only. Plowing is with factory rims with 4 studded snows.
Old Apr 7, 2016 | 01:27 PM
Bruinzfan's Avatar
Bruinzfan
Thank you.. I'll be going with the factory take offs. So what ever the factory options are is what I would end up with. Sounds like I will be fine sticking with those.
Keith
Old Apr 7, 2016 | 01:29 PM
WE3ZS's Avatar
WE3ZS
Yes, you will be fine with any of the factory 20" tire offerings with your setup.
Old Apr 8, 2016 | 04:23 AM
Bruinzfan's Avatar
Bruinzfan
Thank you all! As always all input is my h appreciated.
Keith
TritonBeast
Jan 22, 2018 09:34 PM
Jonnyuma
Sep 25, 2017 06:24 PM
Bite N Hold
Feb 11, 2015 06:48 PM
dennis48755
2015 + Expedition & Navigator
Jan 28, 2015 10:05 AM
Old Brown F250
Dec 5, 2010 11:30 PM
