Sponsored by: Kumho
Tire Pressure
Old Apr 6, 2016 | 10:25 AM
neilwpitts's Avatar
neilwpitts
Tire Pressure
I'm driving a 2003 F-350, 6.0 Lt
What kind of tire pressure are you using when you are not loaded? I've been using the recommended PSI off of the door frame but found that was to much by the centre wearing out to quick.
Couldn't find any related threads on this or just couldn't find it.
Thanks
Old Apr 8, 2016 | 02:34 AM
karlduke's Avatar
karlduke
What tires are you running? You can do the chalk test.
Old Apr 11, 2016 | 10:22 AM
neilwpitts's Avatar
neilwpitts
LT265/75R16 BFGoodrich All-Terrain
I've never heard of the Chalk Test. How do you do it?
Thanks
Old Apr 11, 2016 | 03:53 PM
tjc transport's Avatar
tjc transport
i ain't rite
run a 1 inch or so wide chalk line across the trad of the tire. drive around the block. if the chalk is on the edges of the tire and not the center, tire is over inflated.
if chalk is on the center but not the edges, under inflated. all wore off even, proper inflation.
on my 02 diesel i run 55 front and 40 rear with 285/75/16 tires on stock rims.
Old Apr 13, 2016 | 07:31 PM
RainDesert's Avatar
RainDesert
Thanks
Assuming you have 10ply tires rated at 80psi, I ran 60psi unloaded and 80 when towing heavy. I never had issues.
Old Apr 16, 2016 | 06:24 AM
JWA's Avatar
JWA
For me, running pretty much the same 7800# as a daily driver in an '03 E250 (8,600# GVR) I run 70 PSI all the way around all the time. No adverse or unusual tire wear or handling issues, well over 50K miles on two sets of Michelin LTX's.
When tires are rotated I have to repeatedly tell the techs to inflate to 70 PSI despite what the door sticker says.
peka
Aug 4, 2015 12:36 AM
kupaa
Aug 18, 2010 03:44 PM
Blacknav
Apr 1, 2008 01:23 PM
02Ford150
1997 - 2003 F150
18
Jul 3, 2007 01:44 AM
jetjock16
Nov 12, 2002 09:16 PM
