My 1997 f350 doesn't have a oem single stabilizer...did they come with one and if so is there a place to buy the bracket and hardware kit? This is for the Dana 60 front end.
My truck has a special spring plate with a hole in it. However the long tie rod doesn't have any attachments. I believe there are two part numbers for the long tie rod and one is for a stabilizer....
Two U-bolts go around the tie rod holding an "L" shaped plate into place. On the leg of the "L" is a hole that the steering stabilizer goes through.
If you're handy OP, you shouldn't have any problems making it at home.
