Sponsored by: Real Truck
Dashboss and Ipad
Old Apr 5, 2016 | 09:58 AM
Dave Koehler's Avatar
Dave Koehler
Dashboss and Ipad
I use torque pro but it does have limits like the egt. Looking at the dashboss as an all in one app.
I am not an apple fan so I need some schooling on the Ipad.
I intend to pick up a used one and was wondering about all the different generations.
I care not about all the usual uses for the Ipad. I just want a monitor screen with enough cahones to handle the OBD stream.
Is there any particular version that is best for use in our trucks and the 6.0?
Old Apr 5, 2016 | 10:04 AM
-dave-'s Avatar
-dave-
For your purposes I still think that a much cheaper Droid tablet would be better. What apple app are you looking at that gives you more?
We have a few ipads and minis. Like them because they are simple and just work. The main differences between versions are screen resolution, memory and processor. Our Mini 2 while with older specs does everything just fine.
Old Apr 5, 2016 | 10:07 AM
-dave-'s Avatar
-dave-
how we mount
-dave-'s Avatar
-dave-
Old Apr 5, 2016 | 10:08 AM
-dave-'s Avatar
-dave-
Old Apr 5, 2016 | 10:51 AM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
I would try to find a used iPad Mini. I have an iPhone 6 Plus and the display doesn't scale as the screen size changes; a full-sized iPad would be overkill and not net you anything useful.
Old Apr 5, 2016 | 12:20 PM
Jaime74656's Avatar
Jaime74656
I use the Ipad Mini (I think its the 2nd one?) in the mustang, if you want to see more on my set up click the Torque Pro link in my signature, here is a picture of how I have it set up using the Blue Driver app
Old May 25, 2016 | 10:45 PM
white Buffalo's Avatar
white Buffalo
X2........
I like that the Dashboss can read everything that I want it to plus EGT and fuel pressure. Plus I can e-mail my data logs easily to view on my laptop at home. My IPhone 6 does ok, but I grab my wife's IPad or daughters iPad mini when she's not looking.......
Old May 25, 2016 | 11:34 PM
Firekite's Avatar
Firekite
Fuel pressure? Which engine? You're saying these are items the Torque Pro is incapable of displaying?
Old May 26, 2016 | 12:50 AM
Firekite's Avatar
Firekite
Just got a screenshot in the Torque Pro thread in the 6.7L forum showing all four EGT sensors...
Old May 26, 2016 | 06:43 AM
Crispy71's Avatar
Crispy71
Looked at all the Apple apps and couldn't find any that would give you more data than Torque. I actually went and bought a Samsung Tab just to run Torque for my truck.
There's a 53 page thread on 6.7 Torque PIDs on here and there is a custom 6.7 PIDs list you can download so you don't have to manually input them.
https://www.ford-trucks.com/forums/1...d-pids-52.html
Old May 26, 2016 | 06:44 AM
white Buffalo
The 6.0L. The Dashboss has two optional external sensors that you can add. There 6.0L kit comes with and EGT probe and a fuel pressure sending unit.
Old May 26, 2016 | 08:56 AM
Firekite's Avatar
Firekite
Wow, alright. That's quite the effort. Why the fuel pressure?
Old May 26, 2016 | 08:58 AM
Macrosill's Avatar
Macrosill
The 6.0 does not come from the factory with these sensors so you can not read egt and fue psi through the odb2 port. You have to add sensors and there is no way for Torque to read external sensors. Dashboss can read up to 2 external sensors.
Old May 26, 2016 | 10:36 AM
r2millers's Avatar
r2millers
Not sure I could handle that blue screen of Jaime's for long. I take it that it's only a data logging page, not a driving to view parameters with?
I use my IPad between my seats, using an short power cord to operate, viewing my 12 parameters I want to view the most while driving.
It's larger enough to see easily, including the alarms set, based on each data parameter.
I would recommend an iPad for this to others before my phone.
As see before...
ReddTruck
2004 - 2008 F150
15
Nov 17, 2019 03:29 PM
F250_
116
Dec 5, 2018 11:59 PM
Bmccord03
Aug 11, 2015 08:01 AM
rayezra
Jul 6, 2013 05:34 PM
Greywolf
General Automotive Discussion
Sep 2, 2012 08:12 AM
