Replace Motorcraft 2150 2bbl carb????
Old Apr 4, 2016 | 01:24 PM
grandpas1974's Avatar
grandpas1974
So more than a year ago when getting Grandpa's '74 running again I rebuilt the 2150 carb and it runs pretty good, but the PCV hose connection on the back of the carb had broken off still with the hose connected to the nipple. Since then I have just had it pushed into position, but now I would like to tackle checking/correcting any vacuum issues and I'm not sure if I should replace the carb or just "super glue" this connection back to the carb as a temp fix. The motor is a 302 and it has its own issues including a top end tick that sounds like it is coming from the valve train and probable bad valve stem seals. So until I determine the extent of engine problem I don't want to get crazy with upgrades. Any way to get this vacumm connection back to a good seal?? What to use?? Or just go ahead and throw on a Holley 2bbl?
Old Apr 4, 2016 | 01:33 PM
jbehuniak's Avatar
jbehuniak
I cant see if you posted a pic (work computer firewall) but if you haven't then please post a pic of the broken connection.
What I have learned is, get the engine running correctly before modification. One for a baseline, two to see if you really need to dump money into it.
Good advice which I don't follow. But I would definitely fix the vacuum issues and PCV. Also pull the valve cover off of the side which sounds ticky. It could be serious or nothing much besides wear. It would be a SOB to put all the work in it to find a broken spring or something else.
If the carb is intact meaning the broken part is just the hose, replace the hose. If its the metal barb from the carb then JB weld is your friend. I wouldn't superglue a hose to a carb though.
Old Apr 4, 2016 | 01:41 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
2150's were introduced in 1975, 2100's were used 1963/74.
Old Apr 4, 2016 | 02:39 PM
grandpas1974
I pulled both valve covers over the weekend (although ticking is coming from passenger side) and from what I can tell all the valve train components look okay, no breaks or gouges or anything loose. There is a little side to side play on most of the rockers, but I think that's normal, sorry kind of a newb. No sign of coolant mixing with the oil.
I will try the JB weld for now so that I can vacuum test. I've done a lot of googling trying to find a good vacuum diagram for a '74 302 A/T but haven't come across one and my service manual isn't a lot of help there. Anyone know where I can find one??
Yes ND you are correct it is a 2100, my mistake.
Old Apr 4, 2016 | 02:52 PM
traveler1234's Avatar
traveler1234
Strange, my truck is a 74 F250 360 with a 2150 Carb. Truck was in my father
in laws barn since 81. I believe from the work I've done on, it the 2150
is original.
Old Apr 4, 2016 | 02:56 PM
jbehuniak's Avatar
jbehuniak
https://www.ford-trucks.com/forums/1...then-some.html
has lots-o-diagrams
hopefully its a lifter and the lifter bore is still good. Even better would be a gasket leak. If you like the truck and have the time you'll figure it out, it only takes time and money.
If you have a spare set of hands, pull the coil to distributor wire off. have them crank the truck with the valve covers off and look for anything that's not like the others. Smart move with the vacuum gauge. best of luck you got this
Old Apr 4, 2016 | 03:30 PM
NumberDummy
is original.
Upper pic: 2100 series 2V
Lower pic: 2150 series 2V
65f100pdx
16
Jun 17, 2020 11:34 AM
fordtrck302
1978 - 1996 Big Bronco
Feb 9, 2015 11:53 AM
kilog55
Jan 19, 2007 04:59 PM
truckmano5-2
May 4, 2004 12:56 AM
dbarracuda
Oct 14, 2002 07:51 PM
