Quality Switches
Old 04-03-2016, 10:06 PM
Blue50F-1's Avatar
Blue50F-1
Blue50F-1 is offline
Question Quality Switches
So I've got some pretty big plans for ole blue this summer; God willing, but I was out for a cruise the other day and the engine cut off. Without thinking I hit the starter button and the starter engaged, but no fire. Perplexed, I glanced down and everything was off. So I grabbed the key and immediately power came back. The engine fired right up, and just as quickly died. No power. Repeat this a few times and I'm starting to sweat as traffic gives me confused looks at the intersection.
Short end; ignition switch is wearing out. If the key is turned "just" right we're good to go. Bumped the wrong way and it cuts out.
Anybody know of a source for a quality Acc/Off/On ignition switch? I've cycled through a few headlight switches over the last 18yrs too (ugh...I wasn't that old when I got the truck!) and have only been let down.
I'm not worried about OEM appearance or winning any concourse shows, just something quality.
Any suggestions?
Thanks!
Jim
Old 04-03-2016, 11:30 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
I have a stock switch with key cylinder (but no key), it appears to be a 48-50 style. No bezel. You could swap out lock cylinders. If you want it, it's yours for postage. Can you post a picture of yours at the dash end?
Old 04-04-2016, 12:00 PM
76-5.0's Avatar
76-5.0
76-5.0 is offline
Not trying to be rude, but is there a source for a better quality headlight switch? My 48 has the wrong switch and I am leery of the chinese junk.
Old 04-04-2016, 01:40 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Lots of people using a GM switch, check drptop's threads. I have a universal switch from NAPA, works fine (I'm 12v) and fits OK.
Old 04-06-2016, 09:02 AM
Blue50F-1's Avatar
Blue50F-1
I probably should have mentioned that I'm running 12v as well...don't think that would make a difference on the ignition switch, but not sure off the top of my head.
I'll get a pic of it soon.
My current ignition switch came from Napa if I remember right, but there are no Napa's in my area now.
My current headlight switch came from O'Riely's and it doesn't always make contact at the headlight end or on the dash dimmer. You pull it out and you have to jiggle it to get the headlights to come on (sometimes)...though I've never had them shut off once they came on it makes me a little nervous. Same story with the dash lights, though I have had them go out after going over a rough patch of road and you can't tell how fast you're going or voltage, etc. It's irritating.
Thanks Ross,
Jim
Old 04-06-2016, 09:48 AM
wavetrain75's Avatar
wavetrain75
wavetrain75 is offline
Ron Francis Wiring has good stuff if you can afford it.
Uglyknob
01-03-2015 04:18 PM
Drewski 2
30
11-20-2013 05:08 PM
Woodsman_30350
09-15-2008 04:33 PM
ssj7kids
13
05-06-2008 11:09 PM
capn
06-11-2002 08:10 PM
Quick Reply: Quality Switches
