C1145 ABS code has me confused.
Old Apr 3, 2016 | 07:36 PM
RoryTheFerret's Avatar
RoryTheFerret
My ABS light is on, code is C1145 which is the right front sensor (passenger side?) I looked it up on my workshop manual CD and it says this...
<table border="1" cellpadding="3" cellspacing="0" width="96%"><tbody> <tr> <td> E5 CHECK THE ABS MODULE OUTPUT </td> <td style="BORDER-BOTTOM: medium none"> </td></tr> <tr valign="top"> <td>
  • Connect: ABS Module C135.
  • Key in ON position.
  • Measure the voltage between the suspect wheel speed sensor connector, harness side.
  • Is the voltage greater than 10 volts?
</td> <td style="BORDER-TOP: medium none">Yes
INSTALL a new wheel speed sensor. REFER to Wheel Speed Sensor — Front or Wheel Speed Sensor — Rear in this section. CLEAR the DTC. REPEAT the self-test.
No
GO to E6 . </td></tr></tbody></table>
There is no voltage to the connector on the harness, what the hell happened?
Old Apr 4, 2016 | 11:32 AM
alloro's Avatar
alloro
Since the voltage is not greater than 10V, Go to E6 and continue.
Swisspsd
Jul 20, 2018 04:18 PM
fordboy67
Jan 25, 2017 10:03 AM
meborder
Jan 12, 2017 02:29 PM
Ford'05HG
1983 - 2012 Ranger & B-Series
Jun 1, 2016 07:06 AM
phadams
1997 - 2003 F150
Aug 20, 2009 09:16 PM
