Transfer case stuck in neutral?
The 4x4 has not worked on my 4x4 Explorer Sport Trac for several years!
I removed the Transfer Case Shift Motor, took it apart and cleaned it thoroughly and then I re-installed it.
I turned the truck on put it in Neutral and then moved the switch to 4X4 High... for the first time in a long time I could hear the click underneath the dashboard/floorboard like if it was trying to engage... it did it three or four times and then I switched it to 4X4 Low and it engaged! The little light came on. I tried to back out of the garage and I can hear the transmission shift but it did not move!
I put it in Drive and I can hear the transmission shift over but nothing. The engine would rev up but it wouldn't move forward. I tried putting it in park and it sounded like it grinded gears.
I unplugged the battery for 20 minutes and tried all of this again and nothing.
I got underneath and turned on my cell phone camera under the transmission and repeated the same steps above. I could see the shift lever on the side of the transmission from the column move through all positions.
I tried to push the truck out of the garage in Neutral and I cannot push the truck at all!
Is my transfer case stuck in Netrual? Did fuses blow? I can't leave the garage open all night... any advice would help out!
Did you fix it
Did you find the fix for your truck? I'm having the exact same issues and its driving me nuts !
Bio-Vic
05-19-2023 07:30 PM
Bio-Vic
04-02-2016 09:42 PM
jem44357
01-27-2010 09:13 AM
